Cannot forward broadcast packet to another PC through router
cobobobo88
Hi, i am a student who currently doing my last subject called " Final year project" in my universitiy. I am facing 1 problem now which made me cant proceed to next step of my project. My project title is "Investigating Quality of service (QOS) Requirements for Online Game Applications over IP Switched Network". The experiment pad for this project have 3 pc and 2 router with some other software
The problem i facing is "when Pc1 host a warcraft 3 game, Pc2 cant see any host game from the list in LAN network when they are connected".
The network topology is like that:
Pc1 - [interface 1] Cisco Router [interface 2] - Pc2
IP address:
Pc1          - 192.168.0.18
Interface 1 - 192.168.0.17
Interface 2 - 192.168.2.2
Pc2          - 192.168.2.3
Pc1 can ping to Pc2, so they are connected.
So i keep on doing some accesslist command and other to test whether PC2 can see any game from the LAN list, but cant. End up I open a software call "Wireshark" to see the flow packet for both PC. And i found out something, When PC1 has host/create the game, the wireshark constantly show some udp broadcast packet.
Source: 192.168.0.18 ; Destination: 255.255.255.255 ; protocol : UDP ; source port : 6112 ; destination port : 6112
PC1 keep constantly sending but PC2 cant receive any, and i know the router default blocking any broadcast packet to forward. When i plug them to a cisco switch, PC2 can receive the broadcast packet from PC1.
So my current goal is to let my router forward the broadcast packet to PC2, but i even have try some commandline like
ip forward-protocol udp 6112
ip helper-address
ip directed-broadcast
and others....
and PC2 still cant receive any broadcast packet from PC1.
Is anyone know how to help me solve this situation?
cobo
16 Replies 16
Talha Ansari
While using the "ip helper address" the router will not forward broadcast packets. Router will convert the broadcast into unicast and then forward the packet to the ip address mentioned in combination with helper address command.
So if broadcast is the only critieria for the game to run then the router need to be configured in bridge mode. Or try this command "ip forward-protocol udp" in the config mode and in combination with ip helper address on the interface and do not mention any port number.
Talha
Message was edited by: Talha Ansari
Hi Talha,
I have tried ur combination commandline but still cant work. But i havent try any bridge mode yet. I will study and test it in tomorrow.
Is anyone know my network got any problem that PC2 cant receive any broadcast packet (port : 6112) from PC1 through router?
cobo
Can you post the current configuration of your router so that we have a basic starting point? Thanks!
Best regards,
Peter
Hi peter, this is the current configuration.
Router>ena
Password:
Router#show run
Building configuration...
Current configuration : 3297 bytes
! Last configuration change at 06:53:58 UTC Mon Sep 26 2011
version 15.1
hostname Router
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
enable secret 5 $1$pd4Y$9jsggO916Vaj.XMhL.7l7/
no aaa new-model
no ipv6 cef
ip source-route
ip cef
crypto pki trustpoint TP-self-signed-2102879060
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2102879060
revocation-check none
rsakeypair TP-self-signed-2102879060
crypto pki certificate chain TP-self-signed-2102879060
certificate self-signed 01
  3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32313032 38373930 3630301E 170D3131 30363233 30373432
  30345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31303238
  37393036 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  810097C4 1931E19B 7015BB4D BC7E2101 2C5C252F 18FD8573 5CBBE0B5 186753E3
  4B39BB6D C29BEEBB C97BCC54 B0788587 B47223A6 17D8C65B C17A3C50 0B8FD768
  FC265B2E 78991BD2 6C29FDF6 C3794009 70878DA6 062D6219 71D5F9C5 E8D08DE3
  22A98CAF 428D1E44 7E7C6184 EA2EE560 D7A4DD59 B838A337 EDC324D8 D4BAA899
  15570203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
  551D1104 0A300882 06526F75 74657230 1F060355 1D230418 30168014 517B6070
  9A3351BD 323B30AA 3B0032D0 E4ECF886 301D0603 551D0E04 16041451 7B60709A
  3351BD32 3B30AA3B 0032D0E4 ECF88630 0D06092A 864886F7 0D010104 05000381
  81004E72 5AE3C8E8 A1EBB0A8 922A1BDE 1F3D3826 7B2914C3 794167D3 C97BAE13
  800B2BF6 A8BEFD14 D88681C6 32AAC72B 827A404C 406D5516 2C31FD12 1CC82C9C
  A5858656 81305DAC D8BA00B6 D1F5261A 4ED2DA79 3475DA54 37D575BA BF69D63E
  BE1E1824 51380A9F D1AA1DF0 A5AB3836 71681F78 954D66C6 0A2A9020 BFAFE65E AE49
        quit
license udi pid CISCO2901/K9 sn FGL15042220
username cisco
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ES_LAN$
ip address 192.168.0.17 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.2.2 255.255.255.0
ip broadcast-address 192.168.2.3
ip helper-address 192.168.2.3
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/0/0
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
no ip address
router rip
version 2
network 192.168.0.0
network 192.168.1.0
network 192.168.2.0
ip forward-protocol nd
ip http server
ip http secure-server
control-plane
line con 0
password cisco
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
this picture is capture from wireshark, you can see the PC1 is keep broadcasting the udp packet (port : 6112) after it create game. But Pc2 cannot capture any this udp packet (port: 6112)
cobo
Hi Cobo,
ip helper-address should face the source, not the receiver as in your configuration.
I would also check TTL value for those datagrams.
HTH,
Ivan.
Hi Cobo,
Ivan is correct. If the broadcast sender is on the Gi0/0 interface then the ip helper-address command should also be placed on the Gi0/0. In addition, using the ip helper-address with a particular unicast destination IP address should work, however, if you want to forward the broadcast traffic onto Gi0/1 and still forward it as broadcast, you should use the ip helper-address with the broadcast address of the destination network, i.e. ip helper-address 192.168.2.255
The comment about the source TTL of the broadcast stream is a very important and neglected point - Ivan, thank you very much for pointing that out!
Best regards,
Peter
cobobobo88
Hi Ivan and Peter,
thanks for pointing me the problem, my case is solved!
I clear all the commandline again and give back the same ip address to 2 interface of router.
then i type the following commandline
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#ip forw
Router(config)#ip forward-protocol udp 6112
Router(config)#int g0/0
Router(config-if)#ip help
Router(config-if)#ip helper-address 192.168.2.255
Router(config-if)#interface g0/1
Router(config-if)#ip direct
Router(config-if)#ip directed-broadcast
Router(config-if)#exit
Router(config)#
and now its work, the pc2 is able to receive udp broadcast packet (port: 6112) from pc1 through router
thanks everyone !!
regards
cobo
Sounds good, Tan, good luck with your studies!
You see Peter, the TTL seemed to be sufficient to traverse over the box, only configuration mattered ;)
Cheers,
Ivan.
Ivan,
Yes, obviously it did! But the TTL in these situations is such an obscure thing. I remember making myself an idiot during a basic IP multicast lab - I eloquently explained the basic multicast routing to students, then we configured everything, started the VLC, began streaming some video, and - nothing happened For half an hour I was debugging that pesky thing until I've found out that the VLC was streaming the video using TTL=1 and moreover, that it ignores the TTL setting in the configuration dialog and you have to write it into the output plugin settings manually. Needless to say, students had a perfect time watching me shrink at the console with every failed attempt to get the stream working. Even now I feel my pressure rising ...
Best regards,
Peter
Hey Peter, that's why I always used the ping approach to present multicast working, rather being messed up with 3d party peculiarities. Of course it is less visional(and even just more confusing) but it works!
uh, I had so many pressure conditions when something was not working fine after the perfect theoretical part, so I would rather skip them to be named here ;)
Hi Peter / Ivan,
I wish to know one thing... can we use PBR to forward broadcasts?
Like in this case if I configure PBR in the following way :
access-list 111 permit ip any host 255.255.255.255
route-map B_FW permit 10
match ip addr 111
set ip next-hop 192.168.2.2 or 192.168.2.255
int gig 0/0
ip policy route-map B_FW
So will this forward the broadcast to the destination ?
Talha
Hi Talha,
I have tested but it seems that the PBR does not apply to broadcast packets - which is basically a good thing.
Best regards,
Peter
Well as I know this normally done using at least two hops routers to covert broadcast to multicast then back to broadcast to the recover using one router I think it's tricky using the helper command
As long as this lab setup try the bellow method
The receiving interface will convert the broadcast to a multicast address let's say 239.1.1.1
Use pbr to redirect this traffic based on the port number to a loopback address
In the loopback address convert this multicast to broadcast again and send out the desired outbound interface toward the receiver as per bellow config
Ip forward-protocol udp 6112
Ip access-list extended game
Permit udp any any eq 6112
Route-map map1
Match ip address game
Set interface loopback0
Ip multicast routing
Inbound interface:
Interface gig0/0
Ip multicast helper-map broadcast 239.1.1.1 game
Policy-map map1
Interface loopback0
Ip address 1.1.1.1 255.255.255.0
Ip pim dense-mode
Ip multicast helper-map 239.1.1.1 192.168.2.255 game
Outbound interface
Interface gig0/0
Ip directed-broadcast
Ip broadcast-address 192.168.2.255
Make sure you remove the old condign
The on,y concern I have is that the pbr conflict with helper multicast map order
Good luck
Outbound interface
Hi Marwan,
I am aware of the multicast helper feature. I was simply testing whether a broadcast could in fact be rerouted using PBR. Of course, rerouting via PBR would not change the IP addressing information in the broadcast's IP header. IP helper and IP multicast helper are about converting the header of the broadcast packet: the IP helper replaces the link-local broadcast address 255.255.255.255 with a predefined IP address (which may be unicast or directed broadcast). The IP multicast helper replaces it with a predefined multicast IP address and reconverted into broadcast on another router in the network. You obviously have to run multicast routing for this to work.
Best regards,
Peter
