Cannot get a Internet connection from my CISCO ASA 5510 to my Managed CISCO
andrewgarber
Cannot get a Internet connection from my CISCO ASA 5510 from my Managed CISCO 1841. Standard T-1 Connection from MegaPath.
Updated the CISCO Configuration, please help I know something is causing a issue with a route? I cannot even PING the DNS Servers at Megapath.
The T1 router is configured with NAT off.
Usable IP addresses, for the local network, are as follows:
IP's: 64.32.187.162 through 64.32.187.174 Subnet mask for all IP addresses: 255.255.255.240 Gateway for all IP's: 64.32.187.161 DNS for all IP's: 64.7.11.2and 66.80.131.5”
Here is my CISCO ASA 5510 Config file
Result of the command: "show running-config"
: Saved
ASA Version 7.0(7)
hostname --------INC
domain-name -------INC
enable password xxx
names
dns-guard
interface Ethernet0/0
nameif MEGAPATHT1
security-level 0
ip address 64.32.187.162 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 0
ip address 192.168.189.1 255.255.255.240
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu management 1500
mtu MEGAPATHT1 1500
mtu inside 1500
no failover
monitor-interface management
monitor-interface MEGAPATHT1
monitor-interface inside
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
global (MEGAPATHT1) 10 interface
nat (management) 0 0.0.0.0 0.0.0.0
nat (inside) 10 0.0.0.0 0.0.0.0
route MEGAPATHT1 0.0.0.0 0.0.0.0 64.32.187.161 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd dns 64.x.x.2 66.80.131.5
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd domain PeminicINC
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
service-policy global_policy global
Cryptochecksum:xxx
: end
5 Replies 5
andrewgarber
Some Route is wrong in the Firewall because I cannot get out.
smitty6504
The route is wrong i would try this for the route issue:
route Megapath1 0.0.0.0 0.0.0.0 e0/0
and then also you want your inside interface to have a higher security level then your outside interface, so give this a try:
Int E0/0
security-level 100
I agree my routes are wrong. But when I run the command
Comes back with a
ERROR: % Invalid input detected at '^' marker.
what is the next hop from the outside of the ASA or what is the ip address of the next hop connected to e0/0
route Megapath1 0.0.0.0 0.0.0.0 (enter IP here)
jignesh.p
you have made mistake configuring inside interface. just look below configuration.
your configuration for Inside Interface.
nameif inside
security-level 0
It should be like this
nameif inside
security-level 100
