Cannot get any traffic to flow through NAT besides ICMP ping
jmcdonagh
This is driving me crazy, it's been a solid decade since I administered a Cisco router so perhaps I am doing something really dumb.
The situation is this: I can ping and ssh between the local subnets (wired and wireless). From the router itself, I can ping and lookup hostnames, thus implying TCP and UDP are operational per se.
However, I cannot get any traffic BESIDES ICMP ping to flow from local subnets to the Internet. The NAT translations are there. I can see the packets come back by setting up a packet-trace for ingress on the WAN interface, it says 'punted' which I think on these newer routers just means handing off the CEF? Also, In
sh ip nat stat
 I can see thousands of "Out-To-In Drops". I have no idea why they are getting dropped. I thought that without an ACL on the WAN interface, things are permitted by default? What am I missing? Here is my config:
version 16.7
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname router
boot-start-marker
boot-end-marker
no logging console
enable password password
no aaa new-model
ip name-server 1.1.1.1 8.8.8.8
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.49
ip dhcp excluded-address 192.168.30.1 192.168.30.49
ip dhcp pool wired
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
 dns-server 1.1.1.1 8.8.8.8
 domain-name mydomain.com
ip dhcp pool wireless
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
subscriber templating
license udi pid C1113-8PLTEEAWB sn XXXXXXXXXXX
no license smart enable
diagnostic bootup level minimal
redundancy
 mode none
controller Cellular 0/2/0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
controller VDSL 0/3/0
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 description isp
 ip address xx.xx.xx.xx 255.255.255.252
 ip nat outside
 negotiation auto
interface GigabitEthernet0/1/0
 switchport access vlan 20
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Wlan-GigabitEthernet0/1/8
 switchport access vlan 30
interface Cellular0/2/0
 no ip address
interface Cellular0/2/1
 no ip address
interface ATM0/3/0
 no ip address
 no atm enable-ilmi-trap
interface Ethernet0/3/0
 no ip address
 no negotiation auto
interface Vlan1
 no ip address
interface Vlan20
 description wired
 ip address 192.168.20.1 255.255.255.0
 ip nat inside
interface Vlan30
 description wireless
 ip address 192.168.30.1 255.255.255.0
 ip nat inside
ip nat pool isp xx.xx.xx.xx xx.xx.xx.xx netmask 255.255.255.252
ip nat inside source list 20 pool isp overload
ip nat inside source list 30 pool isp overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.x
access-list 20 permit 192.168.20.0 0.0.0.255
access-list 20 remark NAT Allow for Wired
access-list 30 permit 192.168.30.0 0.0.0.255
access-list 30 remark NAT Allow for Wireless
control-plane
line con 0
 transport preferred none
 transport input none
 stopbits 1
line vty 0 4
 login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
try to use the config below (without the pool), important parts markedin bold:
version 16.7
hostname router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip dhcp pool wired
redundancy
mode none
description isp
ip nat outside
negotiation auto
no ip address
no ip address
interface ATM0/3/0
no ip address
no ip address
no negotiation auto
interface Vlan1
no ip address
interface Vlan20
description wired
ip nat inside
interface Vlan30
ip nat inside
--> ip nat inside source list 20 interface GigabitEthernet0/0/0 overload
no ip http server
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
--> access-list 20 permit 192.168.20.0 0.0.0.255
--> access-list 20 permit 192.168.30.0 0.0.0.255
control-plane
line con 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
either the subnet mask on the interface, or the subnet mask of the pool, are misconfigured.
description isp
ip address xx.xx.xx.xx 255.255.252.0
ip nat outside
negotiation auto
I would suspect the interface IP address, since I don't think your ISP will give you an IP address with a /22 mask. Change the subnet mask to:
description isp
--> ip address xx.xx.xx.xx 255.255.255.252
ip nat outside
negotiation auto
Wow what a bonehead mistake, thanks for pointing that out!
So I fixed that, cleared the NAT translations, still the same issue.
version 16.7
hostname router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip dhcp pool wired
redundancy
mode none
description isp
ip nat outside
negotiation auto
no ip address
no ip address
interface ATM0/3/0
no ip address
no ip address
no negotiation auto
interface Vlan1
no ip address
interface Vlan20
description wired
ip nat inside
interface Vlan30
ip nat inside
no ip http server
control-plane
line con 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
So, your suggestion pretty much fixed it minus the default route, which had to stay with the IP for whatever reason. You are my hero rn Georg. I wonder why it wouldn't work with the pool? Or was it the multiple access lists? I don't get it
