Cannot get Cisco 2800 routers to route
mcardinal
Greetings,
I am studying for my CCNA and got a few routers and switches for a test lab. I am just trying to get 2 Cisco 2800 routers to communicate properly and I am running into problems. I tried first with the serial ports, and now I am trying with Ethernet, but still can't seem to get it. This same configuration works on packet tracer; R1 has internet connectivity, but R2 does not. Can someone please help to point me in the right direction? Thanks in advance for even looking at my request.
My cable modem with builtin router is 10.0.0.0/24.
Port 1 of the cable modem's switch is connected to Gi0/0 on R1 with ip address 10.0.0.40/24
Port Gi0/1 of R1 has ip address 10.1.0.1/24 and is connected to port Gi0/0 on R2 which has ip address 10.1.0.2/24
Port Gi0/0 of R2 has ip address 10.1.1.1/24 and is connected to a Cisco 2960 switch with no configuration (write erase).
R1 can ping 8.8.8.8
R2 can ping 10.1.0.1 and 10.0.0.40, but cannot ping 10.0.0.1 or 8.8.8.8.
R1 configuration
R1#show running-config
Building configuration...
Current configuration : 922 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
hidekeys
interface GigabitEthernet0/0
ip address 10.0.0.40 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.1.0.1 255.255.255.0
duplex auto
speed auto
interface Serial0/3/0
no ip address
shutdown
no fair-queue
interface Serial0/3/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
R1#
R2 Configuration
R2#show running-config
Current configuration : 1154 bytes
! Last configuration change at 02:21:20 UTC Sun Mar 5 2023
version 15.1
no service password-recovery
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2821 sn FTX1107A54P
redundancy
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
ip address 10.1.0.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
ip route 0.0.0.0 0.0.0.0 10.1.0.1
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
end
R2#
Matthew
"When you teach someone what you know, you gain a greater understanding of the subject, which increases your own retention of the knowledge."
just to make sure you understand what is needed, and what @Harold Ritter and @Kasun Bandara correctly suggest, make the changes marked in bold on R1:
R1
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
hidekeys
--> ip nat outside
duplex auto
speed auto
--> ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
no ip address
shutdown
clock rate 2000000
--> ip nat inside source list 1 interface GigabitEthernet0/0 overload
--> ip route 10.1.1.0 255.255.255.0 10.1.0.2
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
--> access-list 1 permit 10.1.1.0 0.0.0.255
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
hi, you need to configure
 NAT in R1 and return route to 10.1.1.1 255.255.255.0 in R1
Good luck
KB
Hi @Kasun Bandara ,
Both NAT and static route to 10.1.1.0/24 are required on R1.
R1
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
hidekeys
--> ip nat outside
duplex auto
speed auto
--> ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
no ip address
shutdown
clock rate 2000000
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
mcardinal
Thanks Georg for your thorough response. I also found a video on YouTube by "itsupportpeople219" that explained how to connect a router to a home network. The video covered a bunch that I did already know, but I figured I would mention it in case anyone else lands here looking for help and needs a step by step tutorial.
I also appreciate the responses by Harold and Kasun which both aimed to steer me in the right direction.
Thank you all!
Matthew
