Cannot get cisco ASR to ping on an interface to host.
Lewis Goulden
Hello I have a cisco ASR 1002 I have plugged a host into an addressed port and the port comes up however the host cannot ping the router and the router cannot ping the host. Neither can router ping its self. I do the same on a cisco 2800 router and it works fine. What's goin on. Is it the fact that this is a ASR router ?
5 Replies 5
alexclarkesmith
Can you share the config (remembering to minimise passwords). I presume there aren't any ACL? If it is a L3 port, have you tried using a crossover cable? Does the interface show as UP?
show ver:
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-IPBASEK9-M), Version 15.2(2)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Mar-12 15:23 by mcpre
IOS XE Version: 03.06.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 13 minutes
Uptime for this control processor is 16 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1000rp1-ipbasek9.03.06.00.S.152-2.S.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor with 1757706K/6147K bytes of memory.
Processor board ID FOX1702H8F8
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
show run:
No l4r_shim subsystem is included in this platform.
Current configuration : 1189 bytes
! Last configuration change at 14:14:28 UTC Mon May 13 2013
version 15.2
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
redundancy
mode none
ip tftp source-interface GigabitEthernet0
interface Loopback0
ip address 192.168.0.1 255.255.255.255
interface GigabitEthernet0/0/0
ip address 10.10.10.1 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
this connection is simply
ASR-Router Gi0/0/0 ---CrossOverCable---> PC
PC is addressed 10.10.10.2/30
i have created a loopback with /32 mask and it cannot be pinged locally on the router console.
show interfaces:
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is 4XGE-BUILT-IN, address is 7cad.740f.e100 (bia 7cad.740f.e100)
  Internet address is 10.10.10.1/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Full Duplex, 100Mbps, link type is auto, media type is T
  output flow-control is on, input flow-control is on
  Last input never, output 00:09:12, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     285 packets input, 51230 bytes, 0 no buffer
     Received 172 broadcasts (0 IP multicasts)
     0 watchdog, 113 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/0/1 is administratively down, line protocol is down
  Hardware is 4XGE-BUILT-IN, address is 7cad.740f.e101 (bia 7cad.740f.e101)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full Duplex, 1000Mbps, link type is auto, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 output errors, 0 collisions, 2 interface resets
GigabitEthernet0/0/2 is administratively down, line protocol is down
  Hardware is 4XGE-BUILT-IN, address is 7cad.740f.e102 (bia 7cad.740f.e102)
GigabitEthernet0/0/3 is administratively down, line protocol is down
  Hardware is 4XGE-BUILT-IN, address is 7cad.740f.e103 (bia 7cad.740f.e103)
  Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
     0 output errors, 0 collisions, 1 interface resets
GigabitEthernet0 is administratively down, line protocol is down
  Hardware is RP management port, address is 7cad.740f.e140 (bia 7cad.740f.e140)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive set (10 sec)
  Half Duplex, 10Mbps, link type is auto, media type is RJ45
Loopback0 is up, line protocol is up
  Hardware is Loopback
  Internet address is 192.168.0.1/32
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Output queue: 0/0 (size/max)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
_________
I hope this is a silly issue that is just down to it being a ASR router,
note router model is Cisco ASR 1002.
Interface gi0/0/0 is using a cisco copper SFP
Router#show hw-module subslot 0/0 entity
WARNING: This command is not intended for production use
and should only be used under the supervision of
Cisco Systems technical support personnel.
Entity state for SPA in subslot 0/0
SPA type:                 (0x5F3) Built-in 4xGE SPA
last spa type:            (0x5F3) Built-in 4xGE SPA
oper_status:              (1) ok
card status:              (2) full
last trap: spa type:      (0x0) not present
last trap: oper status:   (1) ok
last_spa_env_get_ok:      false
last_spa_env_read_time:   (0) 1453154 msecs ago
resync_reqd:              false
resync_count:             0
SPA physical index:       1040
SPA container index:      1000
transceiver 0
  container index:        1091
  module entity index:    1092
  port index:             1093
  chassis index:          0
  operational status:     (2) ok
  non-zero xcvr sensors:
transceiver 1
  container index:        1103
  module entity index:    1104
  port index:             1105
  chassis index:          0
transceiver 2
  container index:        1115
  module entity index:    1116
  port index:             1117
  chassis index:          0
transceiver 3
  container index:        1127
  module entity index:    0
  port index:             0
  chassis index:          0
  operational status:     (6) missing
non-zero SPA temp sensors:
sensor 0 has index 1066
sensor 1 has index 1067
non-zero SPA volt sensors:
all volt sensor indices are zero
many thanks in advance.
You are right, it will probably be something obvious. I can't see anything immediately wrong. You could try forcing speed and duplex settings. I had a similar problem when I used a non-Cisco RJ45 SFP. But you say you are using Cisco. Maybe swap that and the cable if you have spare.
Sorry I can't be more helpful
Yer, its really doing my head in.
The SFP & cable has been changed, but still no luck.
I have never touched an ASR before, but i cannot see them differing that much from a normal Cisco router.
anyone ? any help ?
If you unplug the cable does interface Gig0/0/0 change state?
This part of the output of show interface seems to indicate that it recognizes that it has a copper sfp and negotiation seems normal
Does the output of show arp show any MAC for the PC? I would suggest trying debug arp and attempt ping (be sure that logging monitor is enabled and set to level debug if you use term mon, or make sure that logging buffered is enabled and set to level debug if you use show log). At a minimum it would verify whether the ASR is seeing anything coming from the PC.
Rick
Rick
