Cannot get into my router
Michael Durham
Level 4
Level 4
I have 15 Cisco 2520 routers that i purchased.  ALL of them have the same problem. They boot up then seem to lock up.  At the end of the boot process nothing happens when I press any key on my keyboard.  I also tried to get into the RMON to reload the OS butn when I hit CTRL_BREAK I get the > prompt but again, no input acceptance so I cannot reload the OS.  Any suggestions?
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 14336 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 12.0 may not be correctly understood.
No usable interfaces
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Fri 27-Dec-96 17:33 by loreilly
Image text-base: 0x01010000, data-base: 0x00001000
cisco 2520 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 20607561, with hardware revision 00000003
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
2 Low-speed serial(sync/async) network interfaces.
1 ISDN Basic Rate interface.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
%LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3, changed state to down
0:00:14: %LINK-3-UPDOWN: Interface BRI0, changed state to up
0:00:14: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
0:00:14: %LINK-3-UPDOWN: Interface Serial0, changed state to down
0:00:14: %LINK-3-UPDOWN: Interface Serial1, changed state to down
0:00:15: %LINK-3-UPDOWN: Interface Serial2, changed state to down
0:00:15: %LINK-3-UPDOWN: Interface Serial3, changed state to down
0:00:20: %LINK-5-CHANGED: Interface Serial2, changed state to administratively down
0:00:20: %LINK-5-CHANGED: Interface BRI0, changed state to administratively down
0:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0, changed state to down
0:00:20: %SYS-5-CONFIG_I: Configured from memory by console
0:00:20: %SYS-5-RESTART: System restarted --
0:00:20: %LINK-5-CHANGED: Interface Serial3, changed state to administratively down
Charles Hill
Are you sure of the break sequence that you are using?
The following message "%SYS-4-CONFIG_NEWER: Configurations from version 12.0 may not be correctly understood" is usually an indication the router has been downgraded and the config is from a latter ios and some features may not be available, however this should not cause it not to boot up.
Below are a list of break sequences.
Standard Break Key Combinations
SoftwarePlatformOperating SystemTry This
HyperterminalIBM CompatibleWindows XPCtrl-Break
HyperterminalIBM CompatibleWindows 2000Ctrl-Break
HyperterminalIBM CompatibleWindows 98Ctrl-Break
Hyperterminal (version 595160)IBM CompatibleWindows 95Ctrl-F6-Break
KermitSun WorkstationUNIXCtrl-\l
Ctrl-\b
MicroPhone ProIBM CompatibleWindowsCtrl-Break
MinicomIBM CompatibleLinuxCtrl-a f
ProComm PlusIBM CompatibleDOS or WindowsAlt-b
SecureCRTIBM CompatibleWindowsCtrl-Break
TelixIBM CompatibleDOSCtrl-End
TelnetN/AN/ACtrl-], then type send brk
Telnet to CiscoIBM CompatibleN/ACtrl-]
TeratermIBM CompatibleWindowsAlt-b
TerminalIBM CompatibleWindowsBreak
Ctrl-Break
TipSun WorkstationUNIXCtrl-], then Break or Ctrl-c
VT 100 EmulationData GeneralN/AF16
Windows NTIBM CompatibleWindowsBreak-F5
Shift-F5
Shift-6 Shift-4 Shift-b (^$B)
Z-TERMINALMacAppleCommand-b
N/ABreak-Out BoxN/AConnect pin 2 (X-mit) to +V for half a second
Cisco to aux portN/AControl-Shft-6, then b
IBM CompatibleN/A
Ctrl-Break
Hope this helps...
