how does it work in order if bgp conditional advertisement and route-map
syjeon
I need some more clarification when we use bgp conditional advertisement and route-map both for the particular neighbor. see the below.
ex)
router bgp 1
 neighbor xxx.xxx.xxx.xxx route-map route-map-out-a out
 neighbor xxx.xxx.xxx.xxx advertise-map aaa exist-map bbb
If configuration likes above, I thought either we have both, the route-map can be worked to send the routes to neighbor at final stage. am I right?
Even though advertise-map work if exist-map matched up, the route-map set to deny out for all routes, then, it won't update nothing to neighbor xxx?
Thanks.
dangleminh
Router will not advertise the route that is denied under the route-map.
route-map: match all routes in rib
advertise-map: match only bgp route in rib
Hope this helps.
Minh
dangleminh
Hope this helps.
Minh
