Cannot get PAT working for all my networks.
Networking_Adz
Hi there , I am trying to create a network which will allow me to use PAT on the router although i am having difficulty to make it work. I have R3 being the main router to configure the nat translations. the server connected to R3 is able to ping just fine to ISP network. Other networks are unable to ping the ISP. Vlans are all using dhcp and management is using it too. i have 3 routers in the network excluding the ISP router which uses a different address. R1, R2 and R3
My network structure is as follows
Subnet
VLAN10 ------ 10.0.1.0 /24
VLAN15 ------ 10.0.2.0 /24
VLAN20 ------ 10.0.3.0 /24
Management -- 10.0.4.0 /24
Server ------- 10.0.5.0 /24
R1-R2 ------- 10.0.6.0 /24
R2-R3 ------- 10.0.7.0 /24
R1-R3 ------- 10.0.8.0 /24
PAT network
R3-ISP------- 209.165.100.30 | .17 respectively
where R1 holds all vlans 10,15,20
R2 holds management
R3 holds server and the Isp
all networks are able to ping with eachother just fine. aside from the ISP as mentioned. I am using EIGRP for this network.
R1 ---> Show running config
hostname R1
ip dhcp excluded-address 10.0.0.1 10.0.0.11
ip dhcp excluded-address 10.0.1.1 10.0.1.11
ip dhcp excluded-address 10.0.1.129 10.0.1.139
ip dhcp excluded-address 10.0.2.1 10.0.2.11
ip dhcp excluded-address 10.0.3.1 10.0.3.11
ip dhcp pool VLAN10
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
ip dhcp pool VLAN15
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
ip dhcp pool VLAN20
network 10.0.3.0 255.255.255.0
default-router 10.0.3.1
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 10
ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet0/0.2
encapsulation dot1Q 15
ip address 10.0.2.1 255.255.255.0
interface GigabitEthernet0/0.3
encapsulation dot1Q 20
ip address 10.0.3.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.0.6.1 255.255.255.0
interface Serial0/0/1
ip address 10.0.8.1 255.255.255.0
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 10.0.1.0 0.0.0.255
network 10.0.2.0 0.0.0.255
network 10.0.3.0 0.0.0.255
network 10.0.4.0 0.0.0.255
network 10.0.5.0 0.0.0.255
network 10.0.6.0 0.0.0.255
network 10.0.7.0 0.0.0.255
network 10.0.8.0 0.0.0.255
end
R2 -----> show running config
hostname R2
ip dhcp excluded-address 10.0.4.1 10.0.4.11
ip dhcp pool MANAGEMENT
network 10.0.4.0 255.255.255.0
default-router 10.0.4.1
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
ip address 10.0.4.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 10.0.6.2 255.255.255.0
clock rate 2000000
ip address 10.0.7.1 255.255.255.0
clock rate 2000000
no ip address
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
ip classless
ip route 1.1.1.1 255.255.255.255 Serial0/0/1
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
R3 show running-config
hostname R3
no ip cef
no ipv6 cef
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip address 10.0.5.1 255.255.255.0
ip access-group 1 out
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 10.0.7.2 255.255.255.0
ip nat inside
ip address 10.0.8.2 255.255.255.0
ip nat inside
clock rate 2000000
ip address 209.165.100.30 255.255.255.240
ip nat outside
clock rate 2000000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
ip nat inside source list 10 interface Serial0/1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Loopback1
access-list 10 permit 10.0.0.0 0.0.255.255
line con 0
line aux 0
line vty 0 4
login
end
I have posted a picture of my network below. Sorry about the post being kind of messy, its my first time posting on a cisco forum.
Francesco Molino
First, you don't have to declare all your network statements on all routers. You have to make network statement for local subnets. For examlle R3, doesn't have all you subnets and should only have network statements with its local subnets. As R1 is the one having all subnets, it will have all network statement.
Then on R3, why you have a default route pointing to your loopback? The default route sound ehave your isp router ip as next hop (isp ip sitting in the same subnet as your s0/1/0 interface.
After having done that, you'll need to advertise this default route to your routers over eigrp. There are different methods (redistribution, network statement, summary). For example, this is the redistribution method:
redistribute static metric 1544 10 255 1 1500
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
luis_cordova
Hi @Networking_Adz
Try this changes:
R1
router eigrp 1
no auto-summary
no network 10.0.4.0 0.0.0.255
no network 10.0.5.0 0.0.0.255
no network 10.0.7.0 0.0.0.255
R2
router eigrp 1
no auto-summary
no network 10.0.1.0 0.0.0.255
no network 10.0.2.0 0.0.0.255
no network 10.0.3.0 0.0.0.255
no network 10.0.8.0 0.0.0.255
R3
router eigrp 1
no auto-summary
no network 10.0.6.0 0.0.0.255
redistribute static <— this command ensures that the default static route is learned by the other EIGRP routers.
no ip route 0.0.0.0 0.0.0.0 Loopback1
ip route 0.0.0.0 0.0.0.0 s0/1/0
I recreated your topology, have a look at the revised project (version 7.3.0 is required)...
