Cannot get to my web server. How to format my ACL?
Daniel Perez
Please help. Thank you for looking into this problem. This is for a Cisco 851W
This  is a somewhat newb question and I am reluctant to find out how easy  this fix is but I have spent countless hours trying different config  setups and I just cant seem to get it to work.
I have basically scrapped my entire configuration file and started from scratch.
I  have a dynamic ip address for the Wan. I have a client that runs on the  web server to update my DYNDNS records. No problems with address  resolution.
My web server sits on the Lan side at 192.168.1.60  listening on port 80. Could someone look at this config file and tell me  the correct lines I need to forward web traffic to the server?
I have tried "ip nat inside source static tcp 192.168.1.60 80 Inteface FA4 80"  and I messed with the ACL's but no dice. I think my problem will be with the ACL's. I have removed any ACL entries I attempted from the attached file.
I  am certain the web server is working and I can get to it locally typing 192.168.1.60 in my browser. Also as a test I switched SDM  from listening on 8080 to 80 and I get a response from it when I try to  access the web server. I do realize that HTTP is not a secure channel  for SDM credentials but I only did it as a test to see if I could get a  response.
All corrections and/or tweaks are highly appreciated.
Here is my config:
no service pad
service password-encryption
hostname MyRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$vUin$z8jVWcVxL3hIVSF3.P5q55
enable password 7 141B171305072528A8
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
crypto pki trustpoint TP-self-signed-1309454896
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1309454896
revocation-check none
rsakeypair TP-self-signed-1309454896
crypto pki certificate chain TP-self-signed-1309454896
certificate self-signed 01
3082024F 308201B8 A0030311 02020101 300D0609 2A864886 F70D0101
31312F30 2D060355 04031329 494F532D 53656C56 2D536967 6E65642D
C6608620 598A14DA 65E820EF 29D603FC D8703B............................
quit
dot11 ssid GenLabs
dot11 ssid GenLabsGuest
vlan 20
authentication open
authentication key-management wpa
wpa-psk ascii 7 0815444B3B16071806182D162F082B253A3B25
dot11 ssid Genlabs
vlan 1
authentication open
guest-mode
wpa-psk ascii 7 091D545D4B5014131818082F
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp pool Internal-Net
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name MyDomain.local
lease 4
ip dhcp pool VLAN20
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
lease 4
ip cef
ip inspect name MYFW tcp
ip inspect name MYFW udp
no ip domain lookup
ip domain name MyDomain.local
username Generatorlabs privilege 15 password 7 10420C010C141D055D
archive
log config
hidekeys
bridge irb
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip access-group Internet-inbound-ACL in
ip inspect MYFW out
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1460
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
no dot11 extension aironet
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
encryption mode ciphers aes-ccm
ssid GenLabs
ssid GenLabsGuest
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
description Guest wireless LAN - routed WLAN
encapsulation dot1Q 20
ip address 192.168.2.1 255.255.255.0
ip access-group Guest-ACL in
ip inspect MYFW out
ip nat inside
interface Vlan1
description Internal Network
no ip address
ip nat inside
bridge-group 1
interface BVI1
description Bridge to Internal Network
ip nat inside
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
ip http port 8080
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.60 80 interface FastEthernet4 80
ip access-list extended Guest-ACL
deny   ip any 192.168.1.0 0.0.0.255
permit ip any any
ip access-list extended Internet-inbound-ACL
permit udp any eq bootps any eq bootpc
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any traceroute
permit gre any any
permit esp any any
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
password 7 030888130F0C2E421F
no modem enable
line aux 0
line vty 0 4
password 7 07032457110A160B46
scheduler max-task-time 5000
end
Giuseppe Larosa
Hello Daniel,
on your WAN interface Fas4 you have applied an inbound ACL that doesn't allow http sessions started from outside
you have also configured CBAC and you have it applied outbound on the same interface Fas4.
The question is that HTTP sessions are started from client that is on outside world, so even if you haven't provided the configuration of  the CBAC policy  MYFW we can say that there is no way for CBAC to be of help in this case.
It is helpful in opening temporary permit statements for sessions started from inside to outside not the opposite.
You would need a line that allows HTTP traffic inbound like
permit tcp any any eq http
to be added to access-list
the real issue is that you cannot know what IP address you get from DHCP in advance so this is not totally safe, but it can demonstrate where the problem is.
Hope to help
Giuseppe
8 Replies 8
Giuseppe Larosa
Hello Daniel,
Hope to help
Giuseppe
Giuseppe:
I tried it again and it worked this time. I know I tried this same combination before but here is where my snag is.
If I try to access www.mysite.com from inside the lan it will not work. If I do it from a completely different network it resolves ok.
So if I may ask you advice again I have 3 questions:
a) Why does the domain name not resolve on the local network? If my LAN's DHCP server is dishing out addresses and DNS server info to each client wouldn't any DNS request ulitimately be passed on to my ISP's DNS servers and then re-routed back to me?
b) I quote the following statement: "the real issue is that you cannot know what IP address you get from DHCP in advance so this is not totally safe" This confuses me a little. If I have all port 80 traffic being forwarded to a specific IP address on the LAN how does it become unsafe for the rest of the network by using 'permit tcp any any'?
c) Is there no command convention that can be used to capture the Dynamic WAN address in ACL commands? EX something like 'permit any fa4 dhcp eq www' (I realize this is not a legal command)
This boggles my mind because I have used many of the GUI based low-end SOHO products by Cisco (RV042) and implementing a simple web forward always is an option on these devices even when using Dynamic DNS. I love the 851/871, so much so that I created digital art with it (see photo) but I have to admit it is not the most inuitive device.
Thanks to all for any help.
ashok_boin
Level 5
Level 5
You may consider Reflexive ACLs for your purpose.
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfreflx.html#wp1001270
Regards..
-Ashok.
With best regards...
Ashok
Hi Ashok,
He wants to initiate connections from outside to his internal server so reflexive ACLs won't help at all as they are only used to open holes in a restrictive ACL permitting return traffic to go through the firewall but here it is not return traffic , it is initial traffic so he must permit tcp from any to any on port 80 as was already answered by Giuseppe.
Regards.
Alain.
Sorry for the duplicate post. I put my initial response in the wrong place.
Thank you everyone for your responses. I always find good information on this forum.
Giuseppe:
I tried it again and it worked this time. I know I tried that same ACL combination so I can't explain what went wrong. Here is my current snag.
This boggles my mind because I have used many of the GUI based low-end SOHO  products by Cisco (RV042) and implementing a simple web forward was always an EASY option on these devices even when using Dynamic DNS. I love the  851/871, so much so that I created a working digital art piece with it which is hung on my wall (see photo). I still have to admit, it is not the most inuitive device.
Daniel,
1) your ISP DNS reply will give you the public address not the LAN address unless you do what is called DNS doctoring but I don't think this is a feature of the 800 serie.
2)
permit tcp any any
so you are permitting http connection to anybody in your LAN not just the server with the static PAT
3) I think you can use hostnames in your ACL
It's because you are accustomed to SMB routers with GUI that you find the 800 serie non intuitive but once you have played more with it you'll see you can do more stuff with the CLI than on any other low end router.
Regards.
Alain.
After some thought, why couldn't I use "tcp any host 192.168.1.60 eq www"? Wouldn't that close the scope on that ACL?
No you can't use this address as it is a private address which is not routeable on the internet and so will never appear as destination IP.
Regards.
Alain.
