Cannot get Tunnel Interface to route
jjevans1
Hello All,
I have three routers in a lab with BGP peering.
Router 1  - Location A
Router 2 – ISP
Router 3 – Location B
I cannot seem to get the tunnel interface to come up because I cannot ping the other side.
I can ping all interfaces but the tunnel interface.
I am missing something and cannot figure out what it is. I am not worried about the IPSec configuration. I have that working in a different lab.
Any insight is appreciated.
this lab for you
and Friend NEVER advertise the source and destination of tunnel and tunnel itself via same IGP/BGP NEVER
this case in tunnel cause recursive routing
Router1#show running-config
Building configuration...
Current configuration : 2005 bytes
! Last configuration change at 22:32:42 UTC Fri Mar 22 2024
version 15.2
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
ip address 5.0.0.1 255.255.255.0
tunnel source Loopback0
tunnel destination 2.2.2.2
interface FastEthernet0/0
ip address 100.0.0.10 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/1
no ip address
shutdown
speed auto
duplex auto
router bgp 100
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 100.0.0.1 remote-as 1000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Router1#
Router2#show run
Router2#show running-config
*Mar 22 22:34:05.579: %SYS-5-CONFIG_I: Configured from console by console
! Last configuration change at 22:34:05 UTC Fri Mar 22 2024
version 15.2
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
tunnel destination 1.1.1.1
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 200.0.0.20 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 200
network 2.2.2.2 mask 255.255.255.255
neighbor 200.0.0.1 remote-as 1000
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
ISP#show run
ISP#show running-config
Current configuration : 1844 bytes
! Last configuration change at 22:32:59 UTC Fri Mar 22 2024
version 15.2
hostname ISP
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 100.0.0.1 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 200.0.0.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 1000
neighbor 100.0.0.10 remote-as 100
neighbor 200.0.0.20 remote-as 200
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
10 Replies 10
From my first view this not work.
You need to add new LO in each router (except ISP router)
Advertise these LO in bgp
Use these LO as tunnel source and tunnel destination
MHM
@MHM Cisco World
Thank you for your suggestion. I tried the loopback with the same results.
The loopback was advertised just like the ethernet interfaces. Both interfaces are up, advertised but for some reason not in the BGP routing table.
Can I see your last config
MHM
Yes of course, TY the other side is inversed of course.
Router #1 - Location A
interface Loopback0
description Tunnel Interface
ip address 10.0.0.1 255.255.255.0
interface Tunnel10
ip mtu 1500
tunnel source 10.0.0.1
tunnel destination 20.0.0.1
tunnel mode ipsec ipv4
tunnel path-mtu-discovery
tunnel protection ipsec profile XXXX_IPSEC_PROFILE
router bgp 65530
network 10.1.1.0 mask 255.255.255.0
network 10.0.0.1 mask 255.255.255.0
network 198.145.32.0
neighbor 198.145.32.1 remote-as 65111
this lab for you
version 15.2
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
interface Tunnel0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Router1#
Router2#show run
version 15.2
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
interface Tunnel0
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 200
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
ISP#show run
version 15.2
hostname ISP
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
duplex full
no ip address
shutdown
speed auto
duplex auto
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router bgp 1000
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
Thank you for your config info and warning. Very helpful.
Hello
Site-a =  tunnel key 10
Site-b =  tunnel key 20
Kind Regards
Paul
I read that the tunnel key was just an identifier. I have removed that part from the config but results are the same.
post the full running configs (full output of 'sh run') of all three routers, as IPSec is also involved.
Hello
FYI - The tunnel key will negate communication between the tunnels is they differ
By default the logical tunnel interface will establish as soon as you create it even without any other configuration being applied to it so are you saying the tunnel itself is not establishing or the fact the tunnel protocol is down, if so check the communication between tunnel source/destination ip addressing from each rtr as communication is required for the tunnel to come up.
Also suggest remove IPsec for the time being and just focus on the reachabilty once you have that them append IPsec
Kind Regards
Paul
