Cannot log into Cisco RV325 Router after disabling remote management
jonathancu
Cannot log into Cisco RV325 Router after disabling remote management.
I followed these steps on a Cisco KB article:
Disable Remote Management
To disable remote management, do the following:
  1. Log in to the web-based management interface for the device.
  2. Choose Firewall > General.
  3. Uncheck the Remote Management check box.
and now I cannot log into the web interface.
Has anyone run into this issue.
Reference article:
https://www.cisco.com/c/en/us/support/docs/csa/cisco-sa-rv-stored-xss-vqz7gC8W.html
 I assume that you are trying to access from the Lan interface now?
The article you reference discusses a vulnerability for which there was not a good fix available. It suggested that to "mitigate" the risk from the vulnerability that you disable remote management. You have done that and the risk is mitigated but it impacts your access to the switch. Are you able to access the switch using telnet or SSH?
Rick
