show boottime command on a Cisco 1002-x
nibelungen
hi everyone... i would like to know what does mean this command?
XTG-#show boottime
9581190ms
XTG#show boottime detail
Explode: 37914ms
get_platform: 5ms
setup_platform: 5ms
start_udev: 2336ms
load_modules: 48ms
save_boot_info: 12ms
setup_or_extract_piso: 429ms
extract_piso: 423ms
get_fru_env: 8ms
dual_echo_init: 5ms
get_active_rp: 4ms
load_crash_kernel: 148ms
platform_specific_mount_media: 5666ms
prep_storage: 5636ms
mount_storage: 16ms
check_and_mount_usb: 5ms
check_rmon_and_cpld_compatibility: 11ms
link_ios_device_names_and_launch_net: 52ms
link_ios_device_names: 8ms
launch_net: 35ms
start_misc: 14ms
find_debug_conf: 6ms
conditionally_enable_watchdog: 9ms
find_packages_conf: 2975ms
parse_packages_conf: 24865ms
verify_package_set: 225ms
install_base: 701ms
3pa_setup: 66ms
test_3pa: 59ms
install_all_firmware: 8ms
populate_local: 55ms
fixup_fs: 11ms
flush_piso: 197ms
platform_specific_CSL_setup: 5ms
load_startup_hook: 4ms
rc.sysinit: Initial kernel setup: 6311ms
configure_network: 6ms
mount_proc_sys: 7ms
fix_console_params: 8ms
start_udev_and_read_cmdline: 3497ms
init_modprobe_hotplug: 10ms
init_ide: 5ms
init_scsi_floppy: 15ms
init_network: 21ms
init_sound: 10ms
load_user_def_modules: 4ms
load_modules_vars: 4ms
config_kernel_params: 8ms
set_system_clock: 2368ms
load_keys: 5ms
set_hostname: 5ms
set_fsck_and_other_options: 5ms
check_filesystems: 5ms
unmount_initrd: 6ms
remount_root_rw: 7ms
mount_other_filesystems: 5ms
set_platform_and_board_type: 7ms
mount_mtd: 4ms
configure_sysinit_rp: 116ms
make_var_dirs: 7ms
init_random_no_gen: 7ms
cleanup_root_and_vars: 7ms
reset_pam_cons_perms: 4ms
cleanup_utmp_and_wtmp: 7ms
clranup_tmp_bits: 6ms
init_serial_ports: 4ms
load_ide_scsi: 5ms
cleanup_utmp_and_wtmp: 6ms
binos: IOSXE startup activities: 24249ms
Boot wdt tickling: 8ms
Set full default hostname: 6ms
Change the default core pattern: 14ms
check_and_create_dev_node: 7ms
Create HTC node: 5ms
create_fwdir: 22ms
configure_rp: 402ms
binos_set_tcp_params: 16ms
Automatic configuration of ethernet interfaces: 41ms
Bringing up the binos loopback interfaces: 226ms
Brelay configuration: 40ms
make_rsync_dirs_for_rp_fru: 26ms
Set initial time from RP: 6ms
Chasfs initialization: 10667ms
Software internal compatibility checking: 529ms
Software external compatibility checking: 448ms
Checking if a ROMMON upgrade is pending after a reboot: 81ms
upgrade hw-programmable: 322ms
binos_setup_xinetd_rsync_conf: 12ms
Restart xinetd: 254ms
Rsync inbox from active: 155ms
Rsync chasfs from active, if SB: 8ms
check_eusb_capacity: 156ms
Attempt fetch memory from memory table: 24ms
Creating IO module diagnostic links if necessary.: 5ms
Checking for License Daemon initiation: 7ms
Checking for Backplane Switch Manager initiation: 5ms
Checking installer rollback timer expiration: 405ms
ISSU Boottime activities: 8747ms
touch the watchdog: 5ms
dual_rp_standby_set_epoch: 7ms
publish_retrieve: 149ms
Make a backup copy of the provisioning file: 7ms
invoke the _mountpoint_ script for each of the package mountpoints: 88ms
Create the links for the latest cdl files/libraries: 61ms
Create the links for the latest cdl shortlist files: 21ms
Build lua directory: 12ms
Build lua config directory: 445ms
Check boot-time package specific compatibility: 4266ms
Verify the mounts: 63ms
tdl_boot_time_resolve: 3191ms
Cleanup of incomplete corefiles: 26ms
Restarting klogd: 20ms
configure_chassis: 5ms
Process management: 1015ms
IOSD: 9514212ms
IOSD: 31549675ms
IOSD: 1159178ms
IOSD: 84168101ms
IOSD: 495460192ms
IOSD: 2979ms
IOSD: 79470ms
IOSD: 2919ms
IOSD: 122832ms
IOSD: 79771039ms
IOSD: 1293166ms
IOSD: 117657ms
IOSD: 21951ms
IOSD: 1681429ms
IOSD: 59986995ms
IOSD: -3564403ms
IOSD: 185759ms
IOSD: 37233ms
IOSD: 628432ms
IOSD: 132239ms
IOSD: 121931ms
IOSD: 202615ms
IOSD: 250515ms
IOSD: 16147548ms
IOSD: 26223ms
IOSD: 734786ms
IOSD: 87411ms
IOSD: 63211803ms
IOSD: 306896ms
IOSD: 265164ms
IOSD: 4519ms
IOSD: 42038ms
IOSD: 22810ms
IOSD: 2837110ms
IOSD: 1860860ms
IOSD: 730733ms
IOSD: 610056ms
IOSD: 184038ms
IOSD: 25564ms
IOSD: 22994ms
IOSD: 454932ms
IOSD: 1052641ms
IOSD: 2824ms
IOSD: 153441ms
IOSD: 11424ms
IOSD: 1596910ms
IOSD: 122864422ms
IOSD: 148841902ms
IOSD: 213175667ms
IOSD: 1288846271ms
IOSD: 641163352ms
IOSD: 591227793ms
IOSD: 342895674ms
IOSD: 89038ms
IOSD: 83101592ms
IOSD: 24073ms
IOSD: 423109ms
IOSD: 16732ms
IOSD: 573766433ms
IOSD: 10482400ms
IOSD: 6662439ms
IOSD: 451708908ms
IOSD: 57932ms
IOSD: 497168968ms
IOSD: 469999529ms
IOSD: 115176ms
IOSD: 424404828ms
IOSD: 317965ms
IOSD: 56302ms
IOSD: 149183ms
IOSD: 3127ms
IOSD: 428962569ms
IOSD: 75025108ms
IOSD: 70093156ms
IOSD: 35852ms
IOSD: 58452ms
IOSD: 404749ms
IOSD: 13829578ms
IOSD: 248742869ms
IOSD: 2634ms
IOSD: 29430434ms
IOSD: 45785ms
IOSD: 8869ms
IOSD: 94271ms
IOSD: 492132439ms
IOSD: 2513193135ms
IOSD: 98007891ms
IOSD: 637336ms
IOSD: 1302001504ms
IOSD: 80003ms
IOSD: 85676ms
IOSD: 164474002ms
IOSD: 144296ms
IOSD: 306778612ms
IOSD: 8247147ms
IOSD: 16166810ms
IOSD: 238839860ms
IOSD: 9301209ms
IOSD: 154700ms
IOSD: 104485ms
IOSD: 430189855ms
IOSD: 16903ms
IOSD: 8581ms
IOSD: 442528419ms
IOSD: 4959866ms
IOSD: 242911193ms
IOSD: 16007ms
IOSD: 970112ms
IOSD: 1911635ms
IOSD: 11647806ms
IOSD: 543766515ms
IOSD: 71700160ms
IOSD: 263669603ms
IOSD: -30449192382ms
IOSD: 236002460ms
IOSD: 288144951ms
IOSD: 41512ms
IOSD: 272150309ms
IOSD: 5217407ms
IOSD: 1266518849ms
IOSD: 169177ms
IOSD: 717798120ms
IOSD: 5469715ms
IOSD: 75118306ms
IOSD: 236684446ms
IOSD: 331481231ms
IOSD: 1910698ms
IOSD: 2754ms
IOSD: 561658ms
IOSD: 6470097ms
IOSD: 33057594ms
IOSD: 889032275ms
IOSD: 426809824ms
IOSD: 169618876ms
IOSD: 944401574ms
IOSD: 763500977ms
IOSD: 1370131382ms
IOSD: 1395498518ms
IOSD: 30724655ms
IOSD: 307756493ms
IOSD: 590743697ms
IOSD: 723757302ms
IOSD: 7319ms
IOSD: 13995ms
IOSD: 350381540ms
IOSD: 733924260ms
IOSD: 499537441ms
IOSD: 594197632ms
IOSD: 1167940580ms
IOSD: 414748495ms
IOSD: 1375476ms
IOSD: 1450402935ms
IOSD: 13312ms
IOSD: 191883317ms
IOSD: 342996022ms
IOSD: 784559923ms
IOSD: 226687825ms
IOSD: 858624626ms
IOSD: 111139401ms
IOSD: 1305600666ms
IOSD: 289757ms
IOSD: 93354497ms
IOSD: 1184840671ms
IOSD: 192545550ms
IOSD: 325488125ms
IOSD: 137442ms
IOSD: 31168ms
IOSD: 129926ms
IOSD: 506388ms
IOSD: 236928ms
IOSD: 207109623ms
IOSD: 177146598ms
IOSD: 405669371ms
IOSD: 200190139ms
IOSD: 1228459993ms
IOSD: 348992ms
IOSD: 106423ms
IOSD: 611097581ms
IOSD: 69873ms
IOSD: 107663ms
IOSD: 372994948ms
IOSD: 85751728ms
IOSD: 689537705ms
IOSD: 75207ms
IOSD: 380325ms
IOSD: 95233763ms
IOSD: 122122ms
IOSD: 770582549ms
IOSD: 1226283330ms
IOSD: 929581268ms
IOSD: 175616815ms
IOSD: 12192007ms
IOSD: 175499967ms
IOSD: 310217145ms
IOSD: 89364288ms
IOSD: 6560927ms
IOSD: 1203763ms
IOSD: 614176441ms
IOSD: 22007208ms
IOSD: 1247087ms
IOSD: 280985450ms
IOSD: 21518421ms
IOSD: 429663418ms
IOSD: -30581843820ms
IOSD: 2318159549ms
IOSD: 260853ms
IOSD: 274641ms
IOSD: 26412ms
IOSD: 511847608ms
IOSD: 76138360ms
IOSD: 80322029ms
IOSD: 522423ms
IOSD: 36954ms
IOSD: 510066970ms
IOSD: 2958174ms
IOSD: 95522085ms
IOSD: 3506ms
IOSD: 1646632ms
IOSD: 68502ms
IOSD: 1848068ms
IOSD: 52954965ms
IOSD: 82321249ms
IOSD: 407228265ms
IOSD: 86483140ms
IOSD: 363921214ms
IOSD: 411850167ms
IOSD: 97957ms
IOSD: 996ms
IOSD: 18201143ms
IOSD: 369337151ms
IOSD: 1362681875ms
IOSD: 72945704ms
XTG#sh ver
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 30-Jan-15 14:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
XTG-CED-MO-CE-A uptime is 3 years, 16 weeks, 4 days, 1 hour, 26 minutes
Uptime for this control processor is 3 years, 16 weeks, 4 days, 1 hour, 27 minutes
System returned to ROM by reload at 07:09:42 METDST Thu Feb 13 2020
System restarted at 07:12:18 METDST Thu Feb 13 2020
System image file is "bootflash:/asr1002x-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 3751704K/6147K bytes of memory.
Processor board ID FOX1913GE80
6 Gigabit Ethernet interfaces
3 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
0 Replies 0
