Cannot login into WEB UI C8300
Gabe215
I have a new C8300 str8 out of the box.
Want to give the gui a test.
set the ip of the g0/0/1 to 192.168.1.1 255.255.255.0
set my PC to .2 etc....connect it.
create my username admin privilege 15 password 0 cisc0
ip http server is in there
ip http authentication local
all the defaults are in there etc....
I can hit the login page in the browser, put my creds.... and bam!!! No luck.
I can ping the router interface from the PC but cant ping my NIC on the PC from the router. (or vise versa) gotta double check in the am.
Thoughts??? What am i missing? This is straight out of the box nothing else configured than whats listed. Trying to do a hurry up and get to the GUI.
Mark Elsen
            >...I can hit the login page in the browser, put my creds.... and bam!!! No luck.
   What do you mean by no luck ? Do you get an authentication error , or something else ?  (Or post a screenshot for instance) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Nevermind. It was my firewall on the PC...........also side note. Line vty 0 30 needs to be set via cli or youll get a basic GUI.
@Gabe215 Interesting observation about the vty lines. Can you post a screenshot of the 'basic' GUI you get when you don't configure line vty 0 30 ?
