Cannot mark packet with ip dscp using class & policy map
sam-lee
I cannot mark the packet based on tcp(ftp) even tough I have configure class-map and policy-map.
Sh policy int tells me that the packets not marked after I start my ftp data tramsfer.All the packet goes to class default.
I attahced config at both sides.
pkhatri
Level 11
Level 11
Try the following:
- enable CEF on both routers using 'ip cef'
- change the class-map to be the following:
class-map match-all ftp
match protocol ftp
Pls do rate the post if it helps.
Paresh
