Cannot Ping External IP
arromaysael
Can anybody help me for my configuration. I cannot Ping External IP,
I used a method of tftp for ip addresses because I can't save on my nvram method.
The version of 16.03.09 fuji for ISR 4431 series.
Please check my config :
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot system flash bootflash:isr4400-universalk9.16.09.03.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$wjwO$jp7pAoGdo3Ta1cGsfj3Ts.
enable password xxx
no aaa new-model
ip name-server x.x.x.x x.x.x.1 8.8.8.8 192.168.3.1 x.x.x.5 x.x.x.5
ip dhcp excluded-address 192.168.3.1 192.168.3.100
ip dhcp excluded-address 192.168.3.150
ip dhcp excluded-address 192.168.3.249
ip dhcp pool Cisco
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server x.x.x.x x.x.x.1 8.8.8.8 192.168.3.1 x.x.x.5 x.x.x.5
lease infinite
login on-success log
subscriber templating
username x privilege 15 password 0 x
username admin privilege 15 password 0 x
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address x.x.x.x 255.255.255.248
ip nat outside
negotiation auto
spanning-tree portfast
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
ip address 192.168.3.1 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
ip address 10.10.10.1 255.0.0.0
negotiation auto
no mop enabled
interface Vlan1
no ip address
shutdown
ip nat inside source static tcp 192.168.3.5 8080 x.x.x.x 8080 extendable
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source list 197 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip dns server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
access-list 197 permit ip 192.168.3.0 0.0.0.255 any
access-list 197 permit ip any any
route-map track-primary-if permit 1
match ip address 197
match interface GigabitEthernet0/0/0
set interface GigabitEthernet0/0/0
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxx
login local
length 0
transport input ssh
end
Georg Pauwen
from where to wher are you trying to ping (what is the source and destination) ?
Try the simplified configuration below (changes marked in bold):
version 16.9
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password xxx
no aaa new-model
ip dhcp pool Cisco
lease infinite
redundancy
mode none
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
ip nat inside
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
no mop enabled
interface Vlan1
no ip address
shutdown
--> no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip http server
ip dns server
access-list 1 permit 192.168.3.0
--> no route-map track-primary-if permit 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxx
login local
length 0
transport input ssh
end
ssambourg
Could you please share the output of the show ip nat translation command ?
Georg Pauwen
version 16.9
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password xxx
no aaa new-model
ip dhcp pool Cisco
lease infinite
redundancy
mode none
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
ip nat inside
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
no mop enabled
interface Vlan1
no ip address
shutdown
ip http server
ip dns server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxx
login local
length 0
transport input ssh
end
version 16.9
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password xxx
no aaa new-model
ip dhcp pool Cisco
lease infinite
redundancy
mode none
ip nat outside
negotiation auto
no ip address
shutdown
negotiation auto
ip nat inside
negotiation auto
no ip address
shutdown
negotiation auto
negotiation auto
no mop enabled
interface Vlan1
no ip address
shutdown
ip http server
ip dns server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password xxx
login local
length 0
transport input ssh
end
