Cannot ping its own interface help [Basic]
KemalRzky_
ping
Protocol [ip]:
Target IP address: 192.168.254.109
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Ingress ping [n]:
Source address or interface: GigabitEthernet0/0
DSCP Value [0]:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0x0000ABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.254.109, timeout is 2 seconds:
Packet sent with a source address of 192.168.254.109
Success rate is 0 percent (0/5)
But it can show neighbor :
Cisco-3650-109_Sr#sh cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
MikroTik-CRS-202_Sr
Gig 0/0 96 R MikroTik sfp-sfpplus2
MikroTik-CRS-202_Sr
Gig 1/0/23 96 R MikroTik Bridge-iSCSI/ether24-to-201
MikroTik-CRS-201_Sr
Gig 0/0 109 R MikroTik Bridge-Port-LAN/Bonding to CO
RT CORE GEMAPRO Gig 0/0 80 R MikroTik Bridge-Port-LAN/ether10
Total cdp entries displayed : 4
sho int GigabitEthernet0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is RP management port, address is 00b7.7129.0680 (bia 00b7.7129.0680)
Internet address is 192.168.254.109/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 128/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is auto, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:16, output 00:00:15, output hang never
Input queue: 0/75/3883676/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 45000 bits/sec, 49 packets/sec
4341103 packets input, 640195068 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
3883676 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
86879 packets output, 7741766 bytes, 0 underruns
0 unknown protocol drops
2 lost carrier, 0 no carrier, 0 pause output
Giuseppe Larosa
Hello @KemalRzky_ ,
post
show run int gi0/0
show ip vrf
a possible explanation is that the interface is member of a VRF and so it cannot pinged normally you should ping vrf <vrf-name> 192.168.254.109.
Some devices have a built in VRF named management and this can be your case as gi0/0 can be the management interface.
usually on switches the first user data port is something like gi0/1
Hope to help
Giuseppe
Hi sir,
Thankyou for your answer..
I have checked the system and it shows:
#show run int gi0/0
Building configuration...
Current configuration : 175 bytes
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 192.168.254.109 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
end
#sh ip vrf
Name Default RD Interfaces
Mgmt-vrf <not set> Gi0/0
What should i do next, if i still want to use Mgmnt Ethernet?
I'm sorry for this basic question '')
Hello @KemalRzky_ ,
move the configuration to another interface on the switch without the line
vrf forwarding Mgmt-vrf.
and adding the line
no switchport
! to be able to give an IP address to it
Gi0/0 is dedicated to management purposes and have some limitations give it a different IP address in a different IP subnet and do not use it for the moment.
Hope to help
Giuseppe
