Cannot ping Router from multilayer switch and viceversa
mc35109
I'm new in networking and  I'm working on this network assignment for uni and i've been stuck for a few hours now. I'm not able to ping the router from the multilayer switch or the otherway around.
This is my router configuration
hostname Router
ip dhcp pool Sales
network 10.10.33.0 255.255.255.192
default-router 10.10.33.1
dns-server 10.10.33.114
ip dhcp pool Finance
network 10.10.33.64 255.255.255.240
default-router 10.10.33.65
ip dhcp pool HR
network 10.10.33.80 255.255.255.240
default-router 10.10.33.81
ip dhcp pool Admins
default-router 10.10.33.97
ip dhcp pool Server
ip dhcp pool Wireless
network 192.168.33.0 255.255.255.0
default-router 192.168.33.1
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 10.10.33.114 255.0.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router rip
ip classless
ip route 10.10.33.0 255.255.255.192 10.10.33.1
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
and my Multilayer switch config
hostname SWD_1
ip dhcp excluded-address 192.168.33.1
no ip cef
ip routing
no ipv6 cef
spanning-tree vlan 1 priority 24576
interface GigabitEthernet1/0/1
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
shutdown
interface GigabitEthernet1/0/9
shutdown
interface GigabitEthernet1/0/10
shutdown
interface GigabitEthernet1/0/11
shutdown
interface GigabitEthernet1/0/12
shutdown
interface GigabitEthernet1/0/13
shutdown
interface GigabitEthernet1/0/14
shutdown
interface GigabitEthernet1/0/15
shutdown
interface GigabitEthernet1/0/16
shutdown
interface GigabitEthernet1/0/17
shutdown
interface GigabitEthernet1/0/18
shutdown
interface GigabitEthernet1/0/19
shutdown
interface GigabitEthernet1/0/20
shutdown
interface GigabitEthernet1/0/21
shutdown
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
interface Vlan10
mac-address 0090.0cc1.0a01
ip address 10.10.33.1 255.255.255.192
ip helper-address 10.10.33.114
interface Vlan20
mac-address 0090.0cc1.0a02
ip address 10.10.33.65 255.255.255.240
interface Vlan30
mac-address 0090.0cc1.0a03
ip address 10.10.33.81 255.255.255.240
interface Vlan40
mac-address 0090.0cc1.0a04
ip address 10.10.33.97 255.255.255.240
router rip
ip default-gateway 10.10.33.114
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Any help would be very appreciated, thank you!
Martin L
several ways to solve this; with RIP running on both or not (sub-interfaces and ROAS). here is one of options. see attached
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
mc35109
P.S. whenever I try to ping 10.10.33.114 from my switch it won't work or if I'm trying to ping 10.10.33.1 from the router it will not work either
Martin L
zip your PT file and attach here; it be faster to spot issue
Here is the zipped pkt file, thank you
router and switch do not share subnet; they are on different networks; switch has /26 and then /28 but rotuer has /8 with 10.10.33.114 255.0.0.0 .
there should be link that both devices share subnet on it.  i guess  make all subnet /28 on switch, then change /8 to /28 on rotuer
Regards, ML
what is the password for the multilayer switch ?
mihai, forgot about password, sorry
There are many misconfigurations on all devices. What are the requirements ? Do you need the two multilayer 3 switches function together in e.g. an HSRP setup ?
Martin L
Regards, ML
