02-27-2020 09:16 AM - edited 02-27-2020 09:31 AM
I cannot ping LAN networks behind R1 from PE-1. Even though they are in PE-1 routing table. From R1 I am able to ping LAN networks. SWC I have redistribute EIGRP and BGP. My traceroute from PE-1 towards to LAN network stops on R1. R1 and SWC are running iBGP and R1 with PE-1 are running eBGP.
PE-1#sh ip bgp vpnv4 vrf R1
BGP table version is 245, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S StaleRoutin
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65000:1 (default for vrf R1)
*> 0.0.0.0 189.100.10.1 0 65000 i
*> 1.1.1.1/32 189.100.10.1 0 65000 ?
*> 2.2.2.2/32 189.100.10.1 0 65000 ?
*> 6.6.6.6/32 189.100.10.1 0 0 65000 i
*> 7.7.7.7/32 189.100.10.1 0 65000 ?
*> 172.16.10.0/30 189.100.10.1 0 65000 ?
*> 172.16.10.4/30 189.100.10.1 0 65000 ?
*> 172.16.10.8/30 189.100.10.1 0 65000 ?
*> 172.16.10.12/30 189.100.10.1 0 65000 ?
*> 172.16.10.16/30 189.100.10.1 0 65000 ?
*> 172.16.10.20/30 189.100.10.1 0 65000 ?
*> 172.16.10.24/30 189.100.10.1 0 65000 ?
*> 172.16.100.36/30 189.100.10.1 0 0 65000 i
*> 172.16.100.40/30 189.100.10.1 0 65000 i
*> 172.16.100.44/30 189.100.10.1 0 0 65000 i
*> 172.16.100.48/30 189.100.10.1 0 65000 i
* 189.100.10.0/30 189.100.10.1 0 0 65000 i
PE-1#sh ip route vrf R1 172.16.10.6
Routing Table: R1
Routing entry for 172.16.10.4/30
Known via "bgp 64000", distance 20, metric 0
Tag 65000, type external
Last update from 189.100.10.1 00:39:18 ago <<<<<<<<<<<<< R1
Routing Descriptor Blocks:
* 189.100.10.1, from 189.100.10.1, 00:39:18 ago
Route metric is 0, traffic share count is 1
AS Hops 1
Route tag 65000
MPLS label: none
PE-1#ping vrf R1 172.16.10.6 >>> SWC IP
Sending 5, 100-byte ICMP Echos to 172.16.10.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
PE-1#sh ip bgp vpnv4 vrf R1 summary | b N
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
189.100.10.1 4 65000 30 24 245 0 0 00:18:20 17
R1#sh ip route bgp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 172.16.100.37 to network 0.0.0.0
B* 0.0.0.0/0 [200/100] via 172.16.100.37, 00:13:22
1.0.0.0/32 is subnetted, 1 subnets
B 1.1.1.1 [200/0] via 172.16.100.37, 00:13:22
2.0.0.0/32 is subnetted, 1 subnets
B 2.2.2.2 [200/0] via 172.16.100.45, 00:13:22
7.0.0.0/32 is subnetted, 1 subnets
B 7.7.7.7 [200/1331200] via 172.16.10.2, 00:12:51
172.16.0.0/16 is variably subnetted, 13 subnets, 2 masks
B 172.16.10.0/30 [200/0] via 172.16.100.45, 00:13:22
B 172.16.10.4/30 [200/0] via 172.16.100.37, 00:13:22
B 172.16.10.8/30 [200/0] via 172.16.100.45, 00:13:22
B 172.16.10.12/30 [200/0] via 172.16.100.37, 00:13:22
B 172.16.10.16/30 [200/0] via 172.16.100.45, 00:13:22
B 172.16.10.20/30 [200/0] via 172.16.100.37, 00:13:22
B 172.16.10.24/30 [200/0] via 172.16.100.45, 00:13:22
B 172.16.100.40/30 [200/0] via 172.16.100.37, 00:13:22
B 172.16.100.48/30 [200/0] via 172.16.100.45, 00:13:22
R1#sh run | s router bgp
router bgp 65000
no synchronization
bgp router-id 6.6.6.6
bgp log-neighbor-changes
bgp scan-time 5
network 6.6.6.6 mask 255.255.255.255
network 172.16.100.36 mask 255.255.255.252
network 172.16.100.44 mask 255.255.255.252
network 189.100.10.0 mask 255.255.255.252
neighbor 172.16.100.37 remote-as 65000
neighbor 172.16.100.37 timers 3 9
neighbor 172.16.100.37 next-hop-self
neighbor 172.16.100.37 advertisement-interval 15
neighbor 172.16.100.37 soft-reconfiguration inbound
neighbor 172.16.100.37 route-map CE_TO_SWC-1 out
neighbor 172.16.100.37 maximum-prefix 30 95 warning-only
neighbor 172.16.100.45 remote-as 65000
neighbor 172.16.100.45 timers 3 9
neighbor 172.16.100.45 next-hop-self
neighbor 172.16.100.45 advertisement-interval 15
neighbor 172.16.100.45 soft-reconfiguration inbound
neighbor 172.16.100.45 route-map CE_TO_SWC-2 out
neighbor 172.16.100.45 maximum-prefix 30 95 warning-only
neighbor 189.100.10.2 remote-as 64000
neighbor 189.100.10.2 description PE-1
neighbor 189.100.10.2 advertisement-interval 5
neighbor 189.100.10.2 allowas-in
neighbor 189.100.10.2 soft-reconfiguration inbound
neighbor 189.100.10.2 maximum-prefix 50
maximum-paths ibgp 2
no auto-summary
SWC-1#sh ip route eigrp
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 192.168.60.1 to network 0.0.0.0
D 2.2.2.2 [90/281600] via 172.16.10.2, 00:46:39, Port-channel1
D EX 7.7.7.7 [170/1331200] via 172.16.10.2, 00:46:39, Port-channel1
172.16.0.0/16 is variably subnetted, 17 subnets, 2 masks
D 172.16.10.8/30 [90/307200] via 172.16.10.2, 00:46:39, Port-channel1
D 172.16.10.16/30 [90/307200] via 172.16.10.2, 00:46:39, Port-channel1
D 172.16.10.24/30 [90/307200] via 172.16.10.2, 00:46:39, Port-channel1
D EX 172.16.100.48/30
SWC-1#sh ip route bgp
6.0.0.0/32 is subnetted, 1 subnets
B 6.6.6.6 [200/0] via 172.16.100.38, 00:14:09
B 172.16.100.44/30 [200/0] via 172.16.100.38, 00:14:09
189.100.0.0/30 is subnetted, 1 subnets
B 189.100.10.0 [200/0] via 172.16.100.38, 00:14:09
SWC-1#sh run | s router
router eigrp 10
timers active-time 5
timers graceful-restart purge-time 25
network 1.1.1.1 0.0.0.0
network 172.16.10.0 0.0.0.3
network 172.16.10.4 0.0.0.3
network 172.16.10.12 0.0.0.3
network 172.16.10.20 0.0.0.3
redistribute bgp 65000 metric 1000 100 255 1 1500
redistribute static
eigrp router-id 1.1.1.1
eigrp log-neighbor-warnings 5
eigrp event-log-size 1500
router bgp 65000
bgp redistribute-internal
bgp scan-time 5
network 172.16.100.40 mask 255.255.255.252
redistribute eigrp 10
neighbor 172.16.100.38 remote-as 65000
neighbor 172.16.100.38 timers 3 9
neighbor 172.16.100.38 route-reflector-client
neighbor 172.16.100.38 default-originate route-map Default-Route
neighbor 172.16.100.38 advertisement-interval 15
neighbor 172.16.100.38 soft-reconfiguration inbound
neighbor 172.16.100.38 maximum-prefix 30 95 warning-only
neighbor 172.16.100.42 remote-as 65000
neighbor 172.16.100.42 timers 3 9
neighbor 172.16.100.42 route-reflector-client
neighbor 172.16.100.42 default-originate route-map Default-Route
neighbor 172.16.100.42 advertisement-interval 15
neighbor 172.16.100.42 soft-reconfiguration inbound
neighbor 172.16.100.42 maximum-prefix 30 95 warning-only
SWC-1#sh run | in ip route
ip route 0.0.0.0 0.0.0.0 192.168.60.1
02-27-2020 10:01 AM
can you share 'show ip route x.x.x.x' hop by hop for the source ip and destination ip in both directions.
also no ACLs?
02-27-2020 10:12 AM
There are no ACLs
SWC-1#sh ip route 189.100.10.2 >>>>>>>> PE-1 IP
Routing entry for 189.100.10.0/30
Known via "bgp 65000", distance 200, metric 0, type internal
Redistributing via eigrp 10
Advertised by eigrp 10 metric 1000 100 255 1 1500
Last update from 172.16.100.38 01:17:32 ago
* 172.16.100.38, from 172.16.100.38, 01:17:32 ago <<<<<<<<<<<< R1
AS Hops 0
MPLS label: none
SWC-1#sh ip cef 172.16.100.38
172.16.100.38/32
attached to Ethernet0/3
SWC-1#sh cdp ne Ethernet0/3
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
R1.aldmar.com Eth 0/3 169 R 7206VXR Eth 3/1
PE-1#sh ip route vrf R1 172.16.10.6 <<<<<<<<<<<<< SWC IP
Routing Table: R1
Last update from 189.100.10.1 00:39:18 ago >>>>>>>>>>>>>>>>>R1
AS Hops 1
Route tag 65000
MPLS label: none
PE-1#ping vrf R1 172.16.10.6 >>>>>>>>> SWC IP
