Cannot remove class map from a policy map
bsciarra1
Level 2
Level 2
I am trying to remove a
class map
off of a router, when I do it tells me the
class map
is being used.
So I go to the
policy map
where it is applied and type
no class class-name
it accepts the command but i try to remove the
class map
again and it is still being used.
I check the
policy map
and the
class map
still shows only it is shows as a blank entry with no precedence or access group applied to it.
Any idea how I can remove this
class map
from the
policy map
so i can remove the
class map
from the router?
2 Accepted Solutions
Somasundaram Jayaraman
i believe the
policy map
is applied on any one of the interfaces and acl is matching some traffic and  that is the reason why you are not able to remove the
class map from policy map
Here are the steps to remove a
Switch#conf t
switch(config)# class-map
switch(config-cmap)# no match access-list
switch(config-cmap)# policy-map
switch(config-pmap)# no class
switch(config-pmap)#exit
switch(config)# no access-list
Hope this answers your question.
Cheers
Somu
Rate helpful posts
cadet alain
remove the
policy-map
from the interface with the interface command
no service-policy in|out
then you can remove the
class-map
Regards.
Alain
8 Replies 8
i believe the
policy map
Switch#conf t
Cheers
Somu
Rate helpful posts
I try the command to clear all
policy-map and class-map
clear configure policy-map
clear configure class-map
hope be helpful
cadet alain
remove the
policy-map
class-map
Regards.
Alain
I do not want to remove
class-map
as we have a few ACL listed and nating.
I just want to make sure that the following is removed
  1. policy-map type inspect dns migrated_dns_map_1
  2.         i. parameters
                          message-length maximum client auto
                            message-length maximum 512
                            no tcp-inspection
  1.     b. policy-map global_policy
  2.     i. inspect dns migrated_dns_map_1
                   inspect ftp
                           inspect tftp
  1.    6. following lines were entered by asa
  2.     a. policy-map type inspedct dns migrated_dns_map_2
  3.     i. parameters
                              no tcp-inspection
bsciarra1
Level 2
Level 2
Thank you, you were both right.  The policy was still applied to the interface.
Wish I read your responses before I forged ahead because I ended up removing and re-adding the
policy-map
just to delete my unwanted
class-maps
Either way the QOS configuration has been corrected.  Thanks for your help...
Good Morning.
I would like to thank everyone that has replied and forgive me maybe I am not explaining what I am seeing correctly or I do not understand what I think I understand :). Here is what is going on in a nutshell.  I have a
ASA 5516
with no config. I create a config with no
policy-map
type. It does only included a
Policy-map
global policy with a few entries to inspect. I have created a config template, We have a script that sees that template and changes IP's then pushes out configs accordingly. The configs that are generated are good. However once loaded and the ASA reloads I then  have entries that were not added in the config see below.
Policy-map type inspect dns migrated_dns_map_1
 parameters
  no tcp-inspection
Policy-map type inspect dns migrated_dns_map_2
 parameters
  no tcp-inspection
I also have extra entries within the
Policy-map
global policy that I have not added ( why and how did they get there)
for example the items that I did not add to the config that appear in the
are below.
inspect ftp
inspect tftp
I guess what I do not understand is why they are automatically show up on my ASA config when they are not included on my config that I have built for these ASA's . One reason that I am not understanding what is going on , Is that the items that are appearing within my config after reload should not be there as they were not part of the config.
Thank you again for all help
Resolved (removed match
default-inspection-traffic
djgriggs1
Visitor
Sorry jumped the gun, My solution worked for one day then after another reload the Default Policies took back over ..... UGG!!
At first removing match
seemed to work but the below
policy maps
came back > I need to removing them completely so that they do not return. When I try I get Error:
policy-map migrated_dns_map_1
is being used and hence cannot be removed
 expletives here
We do not have DNS hence we want this removed from the Config ....
Please help
  1.         i. parameters
                            no tcp-inspection
                   inspect ftp
                           inspect tftp
  3.     i. parameters
                              no tcp-inspection
Thank you
