cannot route to server
adiparwita
Community Member
hello all..
i've some problem routing my connection to vpn server
i've vpn connection with IP given from provider: 10.6.7.3 ,  subnet:255.255.255.252  ,  gateway:10.6.7.2
then i set up my router with IP addresed:
Ethernet0 : 10.6.7.3 / 255.255.255.252
FastEthernet0 : 10.20.0.1 / 255.255.255.0
the result is:
ping 10.20.0.1 from PC on LAN (10.20.0.100) : success
ping 10.6.7.3 from PC on LAN (10.20.0.100): success
ping 10.6.7.2 from PC on LAN (10.20.0.100): failed  --> this is my problem
ping 10.6.7.2 from router : success
here is my running config:
Router1700(config)#sh run
Building configuration...
Current configuration : 708 bytes
version 12.2
service password-encryption
hostname Router1700
ip subnet-zero
ip audit notify log
ip audit po max-events 100
interface Ethernet0
description Connection_to_VPN
ip address 10.6.7.3 255.255.255.252
half-duplex
interface FastEthernet0
description Connection_To_LAN
ip address 10.20.0.1 255.255.255.0
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.6.7.2
no ip http server
line con 0
line aux 0
line vty 0 4
login local
no scheduler allocate
end
Router1700#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 10.6.7.2 to network 0.0.0.0
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.20.0.0/24 is directly connected, FastEthernet0
C       10.6.7.1/30 is directly connected, Ethernet0
S*   0.0.0.0/0 [1/0] via 10.6.7.2
can anyone help me?
thanks
5 Replies 5
gamalielcruz
Community Member
From how I understand your statement, 10.6.7.2 is your ISP's side already.
Check with them if they have filtering for ICMP. They may have only allowed ICMP from 10.6.7.3.
Thanks!
cadet alain
IP communication is bidirectional so surely the 10.6.7.2 hasn't got a route back to 10.20.0.0/24 or it filters the ICMP.
Regards.
Alain.
i'm still confused, there are no ICMP filter
i can access or ping 10.6.7.3 from PC (10.20.0.1)
i can access or ping 10.6.7.2 from router
but i cant access 10.6.7.2 from PC
Can you help me?, there may be something wrong with the current config
thankyou
10.6.7.3 is the broadcast address and so 10.6.7.1 replies
the second ping is from router to directly connected  IP
Can you sniff the nic from client while sending ping to 10.6.7.2, if 10.6.7.2 doesn't permit pings from non connected interface and icmp unreachable hasn't been disabled we should see a administratively prohibited icmp message.
Regards.
Alain.
hmm weird...
i leaved for a while, it is suddenly connected himself, hahaha
thank you all..
