Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cannot see all the logs?
get_rthym
Expertise,
I cannot view all the  logs on the router. Logs are there for just 10 mins ago events.
Is there any way to see if interface was down, or line protocol was down before 20 - 30 minutes ago by some other way. I saw interface reset but that couldn't help because i didn't the number before i saw it last time.
lek
Increase the size of your loggin buffer by command
conf t
loggin buffered <4096-2147483647>
Please rate if helpful.
HTH,
Smitesh
conf t
HTH,
Smitesh
