Cannot seem to get Distribution lists to work at all - Especially over a hub and spoke NBMA
David Anderson
I am using Chris Bryants toplogy for a 3 router Hub-and-Spoke through a frame switch setup with a couple extra routers:
The Frame network is running RIP, a router connected to R5 is in EIGRP AS 100, and a spoke has several different OSPF Areas (including Area 0 in the ASBR).
However, I cannot write the most standard list, and have anything happen:
R1:
access-list 55 deny any
conf t
router eigrp 100
distribute-list 55 out rip / fa0/1 (tried both protocol and interface)
cleared ip route * to get a fresh routing table, and R1 still see's all the routes from EIGRP being redistributed into RIP
R2, my spoke router with no other protocols can see it, my OSPF filled spoke router R3 and the virtual-link all the way to R4 can see it.
I've tried this same thing over on the OSPF ASBR of R3, I absolutely cannot get this to filter anything to save my life, help?
No matter how simple the distribute-list, it will not do anything on these routers, and when I do debug ip pack it simply doesn't show any sort of filter messages, however "sh ip proto" on R1 does show that EIGRP is being filtered matching 55.
I have confirmed the ACL with a simple deny any above is configured on R1, applied to EIGRP router config, I've done the same deal for OSPF any just nothing is happening at all - What am I doing wrong?
5 Replies 5
I am not sure if a standard access list is sufficient. To deny RIP and OSPF, I usually use these:
access-list 101 deny udp any any eq rip
access-list 101 deny any any ospf
Your answer really just has the same effect as mine though, they both state deny all traffic (or in dist-list context suppress all route updates) off that interface. I tried it with OSPF on R3 in the lower right hand corner, and that also didn't work.
Does it just not work across an NBMA? or RIP?
I am going to lab this. In the meantime, I somehow seem to remember that the distribute list only works inbound. Can you test that ?
distribute-list xx in
Hello.
I just labbed this, both in and out distribute lists work for RIP (version 1 and 2).
Which IOS versions are you running ? You might want to try prefix lists instead of access lists:
ip prefix-list DENY_RIP seq 5 deny 0.0.0.0/0 le 32
router rip
 distribute-list prefix DENY_RIP in
I will first try what you posted, then I'm going to try to lab without the NBMA between 3 routers, O---OSPF----O---EIGRP----O if it doesn't work, to see if I can get it working at all.
I will post back my findings here, again I appreciate your feedback, I'll be sure to update with my finding!
