Cannot Show Debug Info
PolarPanda
Hi there,
           I tried to troubleshoot a router (ISR 4321) which cannot be login remotely by domain user via radius server. So I enabled debug radius authentication or debug aaa authentication. When I tried to open another window of console and login the same switch via ssh, I didn't see any debug info show up in the previous console. So I did show debug, I got message below. Can anyone tell me why the debug info not automatically populate in the previous console. Thank you.
General OS:
AAA Authentication debugging is on
IOSXE Conditional Debug Configs:
Conditional Debug Global State: Stop
IOSXE Packet Tracing Configs:
Packet Infra debugs:
Ip Address Port
SSH:
Incoming SSH debugging is on
Radius protocol debugging is on
Radius packet protocol debugging is on
Francesco Molino
Not sure i understand your question. Is your question related to debug messages but showing up in your console terminal over ssh access? Have you enabled terminal monitor to see them real time on your console screen?
Otherwise, if that wasn't your question, can you detail please your concern?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
terminal monitor is the command i was looking for. Thanks.
You're welcome
Francesco
