Cannot TFTP To Folder
moman62
Level 5
Level 5
%Error copying flash:c2800nm-adventerprisek9-mz.151-4.M1.bin (Not enough space on device) is the error message when I am trying to send to folder on my windows hard drive.
I was able to TFTP my configs to my pc by enabling windows 10 firewall rules and adding the udp port. I have copied/paste the link for anyone  else who is having issues with TFTP'ng from their cisco appliance to their pc etc.
https://www.youtube.com/watch?v=hsPtoDxn01I
6 Replies 6
Alex Pfeil
Level 10
Level 10
Please see below.
Run dir command and check available space on device. It may require some free space in order to do the copy.
Check the space on the drive you are copying it to.
https://community.cisco.com/t5/network-architecture-documents/tftp-transfer-fails-with-a-not-enough-space-on-device-error/ta-p/3115149
Please rate helpful posts.
Directory of flash:/
1 -rw- 67760352 May 19 2015 05:43:36 -06:00 c2800nm-adventerprisek9-mz.151-4.M1.bin
127119360 bytes total (59357184 bytes free)
RT1LAB#
Seems like I have space to copy from flash to my D drive on pc?
Check that you have write permissions to the tftp folder.
John
**Please rate posts you find helpful**
Leo Laohoo
Uhhhhh .... What are you doing?  If you want to "back-up" the IOS, then go to the Cisco website and download the firmware.
I have the firmware!! I'm trying to backup the firmware on my cisco 2811 router using tftp server and that is the error I'm getting.
