cant configure serial int on 2911/K9
keithsauer507
Level 5
Level 5
Hi folks.  Were bringing up a new site shortly and I'm trying to configure Serial0/0/0 which will be connected to an MPLS over 1.5m T1 line.  I am basically doing a simular configuration as other sites where one of the ethernet interfaces is handed off from a fiber optic wan, but a T1 MPLS is connected to a WIC card and this provides a redundant path (though slower) in case of a fiber cut or equipment failure.  This should be pretty straightforward but it appears as if I have no serial interface on this router.  Card is in and everything, it is a VMIC-3-1MFT-T1/E1 in EHWIC 0.
if I do a sh ip int b I only see these interfaces
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         10.40.0.100     YES NVRAM  up                    up
GigabitEthernet0/1         10.1.0.40       YES NVRAM  up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
No serial!
sh hardware does indicated T1/PRI port
3 Gigabit Ethernet interfaces
1 terminal line
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
I did already try to configure the card as t1 ie)
(config)#card type t1 0 0
etc...
How do I get it to present itself as a usable, configurable serial interface?
I checked our other router that is in service and it's a completely different wic card, but its a 2811 router.  Its a WIC 1DSU-T1V2 in HWIC 0.  I'm wondering if 1)my supplier sent me the wrong card, or 2) the 2911 is a completely different animal compared to the 2811.  I'm just trying to get a base config on it that is very simular to my 2811 but using different IP addresses for the local lan and all the MPLS stuff.
JulietCharlie
Hi Keith,
According to:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8028d2e5.html
yours VWIC3 card are first supported in Cisco IOS Software Releases 15.0(1)M3, 15.1(1)T1, 15.1(2)T. With 15.1(4) M2 you are OK.
Try with:
card type T1 0 0
controller t1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
no shutdown
if not working then wr and powercycle router.
Best regards
jc
7 Replies 7
    You may need to check the IOS as well.
Here you go : http://www.cisco.com/en/US/prod/collateral/routers/ps5855/data_sheet_c36-609138.html
    I'd check the cards by using "show diag" and "show inventory" commands. If it was there then you go to "card type" command.
HTH,
Toshi
The original poster tells us that he has attempted to configure the card
but he has not told us what results he got.
If the card type command was configured and accepted then he should be able to configure the T1 controller, and when he configures the time slots then the serial interface gets created.
But if the card type command was not accepted then we are looking at a very different kind of problem.
So can the original poster provide some clarification?
Rick
Rick
Guess I need a little help on that.  This is just a 1.5 mbps data T1,  No voice.
There were no results.  What do I do for timeslots?  Tried to specify pri-group timeslots 1-24 and it says ISDN switch-type must be set first.  This isn't ISDN though.  Maybe I'm a little confused at this card.
Looking through the configs of the 2811's we have there's nothing really in there to this effect.  I don't even see controller T1 0/0/0 clock source internal cablelength long 0db in the config on the current router in service. I just see
voice-card 0
no dspfarm
Unless configuring this doesnt show in the normal sh run commands.... I didn't setup the original routers.
show diag does see the card:
WIC Slot 0:
        VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
it's on IOS 15.1(4) M2 but I might go ahead and update it to 15.2.
Well it is encouraging that show diag does show the card.
If you configure pri-group you are telling the router that the interface will be ISDN (PRI is an ISDN type interface).
Instead you should try something that looks more like this
channel-group 1 timeslots 1-24
that should give you a regular T1 serial interface that you can configure.
Rick
Rick
JulietCharlie
Hi Keith,
According to:
Try with:
card type T1 0 0
controller t1 0/0/0
framing esf
linecode b8zs
no shutdown
Best regards
jc
Ah thanks guys!  I was a little confused because I've used channel-group's before on switches and I didn't realize that was the command to initialize the T1 side of this card.  It now shows a Serial0/0/0:0 interface that I can now start to configure.
Like I said, I didn't configure the current routers but they use different HWIC cards anyway so I just didnt see this in their configs.
Thanks for all the help everyone!
