Cant get VDSL working on Cisco 887VA
richardchipps
Hi All.
I'm having a bit of a nightmare trying to get the VDSL interface to work on my 887 router.  It was working just fine on standard ADSL but now i have moved over to VDSL i cant seem to get it connected.  When i connect the RJ11 into the back of the router i see the below with logging enabled in the console (seems to be a constant cycle of Virtual-Access1 being up/down):
TheBeast#
Aug  8 17:21:50.282: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to up
Aug  8 17:21:53.290: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to up
Aug  8 17:22:28.034: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Aug  8 17:22:28.038: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Aug  8 17:22:28.642: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
Aug  8 17:22:28.646: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Aug  8 17:22:50.822: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Aug  8 17:22:50.826: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Aug  8 17:22:51.214: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
Aug  8 17:22:51.218: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Aug  8 17:23:13.654: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Aug  8 17:23:13.658: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Aug  8 17:23:13.998: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
Aug  8 17:23:13.998: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Aug  8 17:23:36.674: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Aug  8 17:23:36.678: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Aug  8 17:23:37.230: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
Aug  8 17:23:37.234: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Aug  8 17:23:59.534: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Aug  8 17:23:59.538: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
ATM0 interface has been shut since changing from dsl.
My config is below.  Can anyone advise?
Building configuration...
Current configuration : 2345 bytes
! Last configuration change at 17:19:47 UTC Thu Aug 8 2013
version 15.1
no service pad
hostname TheBeast
boot-start-marker
boot-end-marker
enable secret 4 #########################
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.12
ip dhcp pool HomeNetwork
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 62.24.199.13 62.24.199.23
lease 0 2
ip cef
no ip domain lookup
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ17119094
controller VDSL 0
firmware filename flash:vdsl.bin-A2pv6C035d_d23j
interface Ethernet0
no ip address
ip virtual-reassembly in
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
pvc 0/38
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1432
dialer pool 1
ppp authentication chap callin
ppp chap hostname myispusername
ppp chap password 0 mypassword
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static udp 192.168.0.12 53 interface Dialer0 53
ip nat inside source static tcp 192.168.0.12 80 interface Dialer0 80
ip nat inside source static udp 192.168.0.12 88 interface Dialer0 88
ip nat inside source static tcp 192.168.0.12 3074 interface Dialer0 3074
ip nat inside source static udp 192.168.0.12 3074 interface Dialer0 3074
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
richardchipps
it seems this issue was resolved previous by an IOS update.  i cannot do this however as i have no cisco support contract.
