Cant ping GRE destination
DanielAbergel
Hello All,
i start a new lab with tunnels i set up everything(EIGRP + Tunnel0) but i cant ping from R1 to R2 GRE ip dest.
i set up eigrp and one loopback for every router.
R1 config :
interface Loopback1
ip address 1.1.1.1 255.255.255.0
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
mtu 1476
tunnel source Loopback1
tunnel destination 2.2.2.2
interface FastEthernet0/0
ip address 172.12.123.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 172.12.123.0 0.0.0.255
network 1.1.1.0 0.0.0.255
auto-summary
R2 config :
interface Loopback2
ip address 2.2.2.2 255.255.255.0
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
mtu 1476
tunnel source Loopback2
tunnel destination 1.1.1.1
ip address 172.12.123.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 2.2.2.0 0.0.0.255
auto-summary
i add the diagram here.
at the end i want to ping 10.1.1.2 from R1 and from R2 to 10.1.1.1 and its fails.
someone knows what the problem ?
I just tested your original setup (below) on two real routers, it works perfectly. I am pretty sure it is one of the many flaws in Packet Tracer, which does not feature real, full IOS versions, but rather subsets of commands, with unpredictable results...
R1
interface Loopback1
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
auto-summary
R2
interface Loopback2
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
auto-summary
13 Replies 13
Sergey Lisitsin
DanielAbergel,
First thing you need to check that your EIGRP neighbour relationships have established and that you have both loopbacks learned by the routers. Check the following output:
show ip eigrp nei
show ip route
show ip int brief
and see if anything is not in order. If you want, post the outputs and we can troubleshoot further.
if that is a Packet Tracer project, post the (zipped) .pkt file here...
i attach my packet tracer lab here.
R1
interface Loopback1
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
auto-summary
R2
interface Loopback2
interface Tunnel0
mtu 1476
duplex auto
speed auto
router eigrp 1
auto-summary
sanju
Hi Daniel
please share output to troubleshoot further, configuration looks fine.
R1:
sh ip eigrp neighbors
sh ip route 2.2.2.2
ping 2.2.2.2 source 1.1.1.1
R2 :
show ip route 1.1.1.1
ping 1.1.1.1 source 2.2.2.2
regards
I agree that the partial configs posted look appropriate. Perhaps there is something in the remaining parts of the config that we do not see that contribute to the issue. But I suspect there is some basic connectivity issue that causes the issue. So the suggested outputs (show ip interface brief, show ip route, show ip eigrp neighbor) might be helpful in diagnosing the problem.
I also note that the diagram shows a switch connecting the routers. It might be helpful if we had some information about that switch, perhaps starting with the output of show interface status.
Rick
Hey all,
thanks for try to help,
here the outposts from the commads:
R1#sh ip route 2.2.2.2
Routing entry for 2.0.0.0/8
Known via "eigrp 1", distance 90, metric 156160, type internal
Redistributing via eigrp 1
Last update from 172.12.123.2 on FastEthernet0/0, 00:01:26 ago
Routing Descriptor Blocks:
* 172.12.123.2, from 172.12.123.2, 00:01:26 ago, via FastEthernet0/0
Route metric is 156160, traffic share count is 1
Total delay is 5100 microseconds, minimum bandwidth is 100000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
R1#sh ip eigrp neighbors
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 172.12.123.2 Fa0/0 10 00:01:52 40 1000 0 3
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 1.1.1.1
R2:
R2#sh ip eigrp neighbors
(sec) (ms) Cnt Num
0 172.12.123.1 Fa0/0 11 00:05:14 40 1000 0 3
Routing entry for 1.0.0.0/8
Last update from 172.12.123.1 on FastEthernet0/0, 00:05:20 ago
* 172.12.123.1, from 172.12.123.1, 00:05:20 ago, via FastEthernet0/0
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
and the switch show ip status:
Switch#show interfaces status
Port Name Status Vlan Duplex Speed Type
Fa0/1 connected 1 auto auto 10/100BaseTX
Fa0/2 connected 1 auto auto 10/100BaseTX
Fa0/3 notconnect 1 auto auto 10/100BaseTX
Fa0/4 notconnect 1 auto auto 10/100BaseTX
Fa0/5 notconnect 1 auto auto 10/100BaseTX
Fa0/6 notconnect 1 auto auto 10/100BaseTX
Fa0/7 notconnect 1 auto auto 10/100BaseTX
Fa0/8 notconnect 1 auto auto 10/100BaseTX
Fa0/9 notconnect 1 auto auto 10/100BaseTX
Fa0/10 notconnect 1 auto auto 10/100BaseTX
Fa0/11 notconnect 1 auto auto 10/100BaseTX
Fa0/12 notconnect 1 auto auto 10/100BaseTX
Fa0/13 notconnect 1 auto auto 10/100BaseTX
Fa0/14 notconnect 1 auto auto 10/100BaseTX
Fa0/15 notconnect 1 auto auto 10/100BaseTX
Fa0/16 notconnect 1 auto auto 10/100BaseTX
Fa0/17 notconnect 1 auto auto 10/100BaseTX
Fa0/18 notconnect 1 auto auto 10/100BaseTX
Fa0/19 notconnect 1 auto auto 10/100BaseTX
Fa0/20 notconnect 1 auto auto 10/100BaseTX
Fa0/21 notconnect 1 auto auto 10/100BaseTX
Fa0/22 notconnect 1 auto auto 10/100BaseTX
Fa0/23 notconnect 1 auto auto 10/100BaseTX
Fa0/24 notconnect 1 auto auto 10/100BaseTX
Gig0/1 notconnect 1 auto auto 10/100BaseTX
Gig0/2 notconnect 1 auto auto 10/100BaseTX
DanielAbergel
now i try to make other tunnel from fa0/0 172.12.123.1 to 172.12.123.2 its working but when i try to make tunnel with the loopbacks its not working.
Thanks for the additional information. I still do not see a reason why your tunnel between loopback interface addresses is not working. Please post the output of the commands show ip interface brief and show ip route from both routers. Also perhaps the complete config of the routers.
Rick
Hi Richard,
R1 :
R1#show run
Building configuration...
Current configuration : 996 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback1
interface Tunnel0
mtu 1476
interface Tunnel1
ip address 11.1.1.1 255.255.255.0
mtu 1476
tunnel source FastEthernet0/0
tunnel destination 172.12.123.2
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 11.0.0.0
auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
ip rotue:
Gateway of last resort is not set
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 1.0.0.0/8 is a summary, 00:04:08, Null0
C 1.1.1.0/24 is directly connected, Loopback1
D 2.0.0.0/8 [90/156160] via 172.12.123.2, 00:03:36, FastEthernet0/0
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 10.0.0.0/8 is a summary, 00:03:36, Null0
C 10.1.1.0/24 is directly connected, Tunnel0
11.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 11.0.0.0/8 is a summary, 00:04:08, Null0
C 11.1.1.0/24 is directly connected, Tunnel1
172.12.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.12.0.0/16 is a summary, 00:04:08, Null0
R2:
R2#show run
version 12.4
hostname R2
ip cef
no ipv6 cef
interface Loopback2
interface Tunnel0
mtu 1476
interface Tunnel1
ip address 11.1.1.2 255.255.255.0
mtu 1476
tunnel destination 172.12.123.1
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 11.0.0.0
auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
R2 ip route:
D 1.0.0.0/8 [90/156160] via 172.12.123.1, 00:05:02, FastEthernet0/0
2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 2.0.0.0/8 is a summary, 00:05:34, Null0
C 2.2.2.0/24 is directly connected, Loopback2
D 10.0.0.0/8 is a summary, 00:05:01, Null0
D 11.0.0.0/8 is a summary, 00:05:34, Null0
D 172.12.0.0/16 is a summary, 00:05:34, Null0
DanielAbergel,
Can you please turn on packet debugging and try to ping the tunnel IP address from R1 to R2. The debugging is turned on by
"debug ip packet detail" command.
Thanks all for help seems its problem with the packet tracer client.
