09-05-2013 02:24 AM - edited 03-04-2019 08:57 PM
There is a strange problem with our HSRP configration.
We are using ACE module as a Load balancer for servers.
There is 2 backbone switch 6513 and 2 Ace on them.
The Layer 3 vlan interfaces end up in the ACE context.Under this interface there is a HSRP configration and we can use LB system smothly.
The case is that ,I can't ping the ip address of vlan interface on ACE1 and cant ping VIP of HSRP..BUT i can ping ip adress of vlan interface on ACE2 ..
I am starting ping from both 6513 and the result is same for all context and all loadbalancers..fails to ping VIP of HSRP and ACE1 ,success to ping ACE2 AND system works smooth..
Is there any body have an idea that why my pings fail?
Kaan
09-05-2013 06:55 AM
I'm going to ask the obvious... have you verified that the subnet masks of all devices are correct?
09-06-2013 01:26 AM
What is the point of subnetmask? Yes its correct
It is just a ping problem. We can reach the systems back of the LB
