Capture controller flap with syslog?
ben.peterson
Anyway that I can capture/log a T3 controller that is flapping? The flap is fast enough that the serial interface does not go down and is not captured in the log. On my console I get the following when the controller flaps.
Oct 13 16:56:43.946: %CONTROLLER-5-UPDOWN: Controller T3 2/0, changed state to down
Oct 13 16:56:44.946: %CONTROLLER-5-UPDOWN: Controller T3 2/0, changed state to up
I am trying to log this.
Lucien Avramov
Level 10
Level 10
enable "logging console" and then that will send any message you see on the console to your syslog server.
Lucien Avramov
Level 10
Level 10
Thanks. That was easy.
Great, glad it helped. I guess we can mark this post resolved.
