12-11-2006 10:28 PM - edited 03-03-2019 03:00 PM
Hi guys
anyone can recall Cat5513 backplane captacity ? whats the forwarding bandwidth? if you have any old spec doc, appreciate if you can fwd to me.
Solved! Go to Solution.
12-11-2006 10:36 PM
Hi Alex,
See is this helps you
Ankur
12-11-2006 10:36 PM
Hi Alex,
Ankur
