ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
Cat5500 can't retreive config
olsonc0510
I have little experience with a CAT5500 switch. I have one in Ciscoworks that fails when I try to retrieve inventory or sync archive. I get the following message:
CM0151 PRIMARY RUNNING Config fetch failed for Catalyst5500 Cause: Failed to get the start tag-begin in the configuration PRIMARY-RUNNING config Fetch Operation failed for TFTP. Unable to create a socket to /192.168.168.250 Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.
I assume there is something I need to set up on the switch. Telnet, snmp Read and Write are all successful from Ciscoworks. I also increased the timeout value. Please advise if you have experience with this type of switch.
smahbub
Level 6
Level 6
think, this is an issue with ciscoworks and not the device, check the following link for a similiar issue :
http://wwwin-tools.cisco.com/casekwery/getServiceRequest.do?id=601415713
