11-06-2005 01:22 PM - edited 03-03-2019 10:54 AM
Hello All. I just got my hands on a Cisco 837 router and was wondering if I could get assistance in configuring the device to work with my cable internet account. I need assistance in understanding how to set the E1 (wan connection to assign it self an IP address from my cable modem). I would also like to ask for assistance in setting up dhcp serving with the understanding the WAN connection is assigned dynamically.
I have my CCNA, however I do not have any experince with these router/switch combo devices. Any assistance would greatly be appreciated.
~Vinnie
11-06-2005 02:25 PM
Hello Vinnie,
when you say ´E1 WAN Coonection´, I assume you are talking about PPPoE ?
Here is a basic PPPoE sample config which should work on your 837 (obviously you have to modify the IP addresses and username/password combinations).
Can you try to configure this on your router ? Let me know if you run into trouble...
no aaa new-model
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
description Lan Interface
ip nat inside
no ip mroute-cache
no cdp enable
interface Ethernet1
description ADSL Interface
no ip address
no ip mroute-cache
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
description connection to Internet
p address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxx@adslprovider
ppp chap password 7 xxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxx@adslprovider password 7 xxxxxx
ip nat inside source list 1 interface Dialer1 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
line con 0
line aux 0
transport input all
line vty 0 4
password 7 xxxxxxxx
login
GP
11-08-2005 08:01 AM
Thank you GP for your assistance. However, is there a way for any ports on the 837 to gain its ip address through DHCP from the ISP? The ISP is a cable provider and does not use PPPoE. The Cable modem dishes out a IP address to the connected device via DHCP. I was just wondering if it was possible to set the 837 as a gateway type router. If not, I do understand...the product was free to me so I was just trying to find some use for it.
~Vinnie
