catalyst 3560 ipv6 bgp: route received, but not added to routing table
jperz
hi community,
I have a really weird issue with my cisco catalyst 3560G. After having researched back and forth, I'm running out of ideas ... maybe someone in here is guru enough to help me out!
device: cisco catalyst 3560g
ios: 12.2-53(SE) IP SERVICES
scenario: configured IPv6 iBGP link between this switch and a router. the router is announcing 1 (test) route. the switch sees the route properly, but doesn't add it to routing table (the route never gets to be "best path", although it should be).
here's a config snippet:
ipv6 unicast-routing
interface Vlan311
ip address 10.0.0.1 255.255.255.224
ip access-group 311-out out
no ip redirects
no ip unreachables
no ip proxy-arp
ipv6 address 2001:65F:E1:311::1/64
ipv6 enable
router bgp 12345
bgp router-id 10.9.1.1
bgp log-neighbor-changes
neighbor 2001:65F:E1:311::2 remote-as 12345
address-family ipv4
  no neighbor 2001:65F:E1:311::2 activate
exit-address-family
address-family ipv6
  network 2001:65F:E1::/48
  no synchronization
exit-address-family
the session comes up fine, but note that the path is missing the ">" marker for "best path":
sw01#show bgp ipv6 unicast neighbors 2001:65F:E1:311::2 routes
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
* i2001:1638::/32   2001:65F:E1:311::2
                                                  100      0 6939 51058 i
and finally, here's what "debug" has to add to this:
Jan 16 19:15:27: IPv6RT[FFFF] RIB lookup failed
Jan 16 19:15:27: BGP(1): no valid path for 2001:1638::/32
The peer (2001:65F:E1:311::2) as well as its link-local ip is pingable.
Any hints?
thanks,
jakob
15 Replies 15
inikolova
I've had exactly the same issue to what you describe (with a 3560E) and the TAC team pointed me to bug CSCsy32000 (Although the description doesn't seem to be so much similar to the case here the affected verions and the versions it has been fixed it match
It seem that this has been fixed in 12.2(55)SE (That's why the last test here succeeds.)
It seems we have to upgrade
cheers,
Irena
