Catalyst 3560E and TwinGig
lamanso
Are TwinGig included with the Catalyst 3560E?
It is necesary add this module in another order?
thanks
royalblues
Level 10
Level 10
It comes along with the order and need not be ordered seperately.
But by default the port works in 10 gig mode and always reports eeprom failure error when you use the Gig GBICs. You need to configure the hardware module and select gigabit etherent for them to work
Narayan
royalblues
Level 10
Level 10
Narayan
