Catalyst 4510R remove username and password
paul dungey
How do i go about removing forgotton username and password from the Catalyst switch 4510R after the switch has booted up,
Paul
6 Replies 6
Collin Clark
Do you mean once your're in the CLI?
no username [username]
I dont even get CLI eg (Switch) switch will boot up and i have the option to press enter the customers Motd Banner comes up followed User:  and then password:  this is what i need deleting, am i right in saying I've not gone into CLI mode ?
Paul
OK, you're at the login prompt. I assume you're asking that you do not know the username and password and wondering how to delete and create a username so you can enter the switch? If so you'll need to perform a password recovery on the switch to get into it. Let me dig up a link for you on how to do that.
Hi Colin,
Thats exactly right ! This is a massive leaning curve for me.
Paul
Collin,
Many thanks for your Expert help and support, will try this on the switch in the morning
Kinds regards
Paul
