Full Subnet is not reachable
whitemike
Hello All,
I had a subnet that is our SAN network and it was intentionally isolated from the rest of the network when created. They now want to utilize the email feature on the SAN volume for monitoring purposes, so i needed to connect it to the network. I have done so and can see some IP addresses on the SAN subnet but not all, and not the most important one the SAN volume itself. Here is the config of the SAN switch and the switch that was existing on the network already.
The SAN switch is 2 stacked 3750's and the switch that was already on the network is a 3560, I only included the ports that they are connect to each other on. The SAN switch can ping all nodes attached to it (about 24) but coming from anywhere else on the network I can only see 4 nodes.
TKGDC1_SANS_SW01#sh running-config
Building configuration...
Current configuration : 5680 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname TKGDC1_SANS_SW01
enable secret 5 $1$IrDy$zN4OWOH4qibnZ/E6.l.nI0
enable password 7 143C002B0157386A
username tkgadmin privilege 15 password 7 143C002B0157386A
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
switch 2 provision ws-c3750g-24ts-1u
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode rapid-pvst
spanning-tree portfast default
vlan internal allocation policy ascending
interface GigabitEthernet1/0/24
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan33
ip address 192.168.33.17 255.255.255.0
interface Vlan100
ip address 192.168.42.10 255.255.255.0
ip default-gateway 192.168.61.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.61.1
ip route 10.1.1.0 255.255.255.224 192.168.33.1
ip route 10.1.1.32 255.255.255.224 192.168.33.2
ip route 10.114.248.0 255.255.255.0 192.168.33.6
ip route 172.10.10.0 255.255.255.0 192.168.32.65
ip route 172.10.11.0 255.255.255.0 192.168.32.65
ip route 172.10.12.0 255.255.255.0 192.168.32.65
ip route 172.10.13.0 255.255.255.0 192.168.32.65
ip route 172.10.14.0 255.255.255.0 192.168.32.65
ip route 192.168.32.32 255.255.255.224 192.168.33.2
ip route 192.168.32.33 255.255.255.255 192.168.33.2
ip route 192.168.32.64 255.255.255.224 192.168.33.3
ip route 192.168.38.0 255.255.255.0 192.168.33.2
ip route 192.168.61.0 255.255.255.0 192.168.33.4
ip route 192.168.71.0 255.255.255.0 192.168.33.6
ip route 192.168.200.0 255.255.255.224 192.168.33.2
ip route 192.168.201.0 255.255.255.0 192.168.33.2
ip route 192.168.202.0 255.255.255.224 192.168.33.1
ip route 192.168.202.32 255.255.255.224 192.168.33.2
ip route 192.168.202.64 255.255.255.224 192.168.33.3
ip route 192.168.203.0 255.255.255.0 192.168.33.1
ip http server
control-plane
line con 0
exec-timeout 0 0
login local
line vty 0 4
password 7 105B29470B4540565A053E3C
login
line vty 5 15
login local
ntp clock-period 36029221
ntp server 192.168.42.120 source Vlan100
end
Here is the other switch:
TKGDC1-SW02#sh run
Current configuration : 10874 bytes
version 12.2
no service pad
hostname TKGDC1-SW02
enable secret 5 $1$7Hfy$b3ueU8FkscD.zhRnvTP.r0
username tkgadmin privilege 15 secret 5 $1$8nI7$zRaQl0MpghZBQlWcK0v0A1
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
interface GigabitEthernet0/36
interface Vlan1
no ip address
shutdown
interface Vlan33
description @!$%
ip address 192.168.33.4 255.255.255.0
interface Vlan61
description Private Production
ip address 192.168.61.2 255.255.255.0
interface Vlan62
description ***** VLAN
ip address 192.168.62.2 255.255.255.0
ip classless
ip route 192.168.32.0 255.255.255.224 192.168.33.1
ip route 192.168.42.0 255.255.255.0 192.168.33.17
ip route 192.168.200.0 255.255.255.224 192.168.33.1
ip route 192.168.200.32 255.255.255.224 192.168.33.2
ip route 192.168.200.64 255.255.255.224 192.168.33.3
ip http server
snmp-server community KHT RO
snmp-server community TKG1 RO
snmp-server community TKG2 RW
snmp-server location Data Site
snmp-server contact itdept@kramergroup.com
control-plane
line con 0
login local
line vty 0 4
login local
length 0
line vty 5 15
login
end
Collin Clark
Check the default gateway on the devices that you cannot see (ie SAN Volume).
Collin Clark
I knew that it was something simple, sometimes it takes someone outside to see the issue, thanks.
