Catalyst 6500 single Supervisor with Advanced IP Services SSH IOS
smandrapa
Why it is not possible to order IOS ADVANCED IP SERVICES SSH with Catalyst 6506 with single VS-S720-10G-3C supervisor ?
To be more precise - it is not possible to choose this IOS with single Supervisor in configuration tool.
Giuseppe Larosa
Hello Savo,
this can be a software problem of configuration tool from a technical point of view your choices look like correct: I mean if you install a single VS-S720-10G-3C in 6506 chassis it should work.
I don't know if there is any marketing decision behind this.
You may want to contact your cisco representive to have a confirmation/explanation.
Hope to help
Giuseppe
bgroff
It was an intentional decision on the part of Cisco to only include IP Base with a single supervisor in the 6506 VS bundle. You have the option of either ordering the bundle and adding IP Services via the Spare-CD route, or ordering without doing a bundle.
