Catalyst 6509 losing it's config
gregwoodson
I have a Cat 6509 (IOS / Sup720-3B) that Im testing.  Each time the unit is power cycled it completely loses it's config.  I've checked the config register (0x2102)- why on earth would it lose it's config on reboot?
Greg
You might try to replace NVRAM battery on Sup720.
6 Replies 6
gregwoodson
It seems as if it only loses the config on power cycle.  Not from a standard reload.  It loses it only when power is shut off.
That worked.  Well most of the issues.  Thanks
Would you do a dir all and see if the startup-config is saved under a different name.
Default should be startup-config
Directory of system:/
    2  dr-x           0                    <no date>  memory
    1  -rw-       10222                    <no date>  running-config
   12  dr-x           0                    <no date>  vfiles
No space information available
Directory of tmpsys:/
    6  drw-           0                    <no date>  eem_lib_system
    5  drw-           0                    <no date>  eem_lib_user
    4  drw-           0                    <no date>  eem_policy
    1  dr-x           0                    <no date>  lib
Directory of flexwan-fpd:/
    0  dr--   <no size>                    <no date>
    1  -r--     1225216                    <no date>  CWPA2_FPD_version_10.10
Directory of disk1:/
    1  -rw-    15869156  Oct 10 2013 10:09:20 +00:00  s72033-boot-mz.122-33.SXI12.bin
    2  -rw-    46666996   Jan 1 2000 00:04:50 +00:00  s72033-pk9sv-mz.122-18.SXD7b.bin
    3  -rw-    78546436  Mar 21 2014 09:42:30 +00:00  s72033-advipservicesk9_wan-mz.122-33.SXH7.bin
    4  -rw-   107243532  Oct 10 2013 09:48:24 +00:00  s72033-advipservicesk9-mz.151-2.SY.bin
256503808 bytes total (8167424 bytes free)
Directory of sup-bootflash:/
    2  -rwx    15869156   Jan 1 2000 00:05:59 +00:00  s72033-boot-mz.122-33.SXI12.bin
65536000 bytes total (2999592 bytes free)
Directory of sup-microcode:/
    1  -r--     5815326                    <no date>  CWPA2_version_10.10
    2  -r--     7615806                    <no date>  SIP1_version_10.10
    3  -r--     8181882                    <no date>  SIP2_version_10.10
    4  -r--     4519694                    <no date>  SMSC_version_10.10
    5  -r--    22453326                    <no date>  DRACO2_MP
    6  -r--     8093642                    <no date>  CHEVYS-LC
    7  -r--     9442818                    <no date>  C2LC
    8  -r--      327946                    <no date>  LCP_LX10100
    9  -r--      298256                    <no date>  LCP_LX1000
   10  -r--      320626                    <no date>  LCP_AX1000
   11  -r--      391162                    <no date>  LCP_AX10100
   12  -r--      366670                    <no date>  LCP_CPFAB
   13  -r--      725118                    <no date>  LCP_CPGBIT
   14  -r--      468350                    <no date>  LCP_CP10G
   15  -r--      788910                    <no date>  LCP_CPMBIT2
   16  -r--      889902                    <no date>  LCP_CPMBIT
   17  -r--     1116286                    <no date>  LCP_CPXBIT
   18  -r--       65318                    <no date>  LCP_ABOOT
   19  -r--       60490                    <no date>  LCP_BOOT
   20  -r--     1225250                    <no date>  CWPA2_FPD_version_10.10
73166778 bytes total (0 bytes free)
Directory of const_nvram:/
    1  -rw-           0                    <no date>  vlan.dat
129004 bytes total (129004 bytes free)
Directory of nvram:/
 1918  -rw-       10222                    <no date>  startup-config
 1919  ----          24                    <no date>  private-config
 1920  -rw-       10222                    <no date>  underlying-config
    1  -rw-           4                    <no date>  rf_cold_starts
    2  ----          27                    <no date>  persistent-data
    3  -rw-           0                    <no date>  ifIndex-table
1964024 bytes total (1950654 bytes free)
Directory of bootflash:/
    2  -rwx    15869156   Jan 1 2000 00:22:15 +00:00  s72033-boot-mz.122-33.SXI12.bin
65536000 bytes total (49387492 bytes free)
Directory of dfc#1-bootflash:/
No files in directory
15990784 bytes total (15990784 bytes free)
Router#
It shows to be in NVRAM- this was after it was just saved.  I will pull the same thing after power cycle.
It does show the same thing after power cycle- but it does not let me copy over the startup config to running config.  and it does not load it.  However the config registry is correct.
