Catalyst 8000 Licensing and LTE connectivity
Network-giiig
Dear community,
We intend to purchase a C8200L supporting PIM interface with P-LTEA-EA module,
The licenses we ordered are : C8000-HSEC, DNA-P-T1-E-3Y, SVS-PDNA-T1-E3Y, NWSTACK-T1-E, SDWAN-UMB-ESS and DNAC-ONPREM-PF
Does the above licenses enough for: IPSec tunneling, encryption, using the 3G/4G connectivity via the P-LTEA-EA module ?
Thanks in advance.
OrlandoGM
Hello @Network-giiig
You can verify that information in the following document:
https://www.cisco.com/c/dam/m/en_us/products/software/dna-software/dna-software-sd-wan-routing-matrix/pdf/C95-742999-10_Cisco_dna_software_sd_wan_and_routing_matrices_v3a.pdf
Please refer to the section "Cisco DNA for Routing perpetual features".
Hope is useful. Cheers,
Orlando González.
OrlandoGM
Orlando González.
Hello
It looks like you have a  3year tier1 on premise licence , that should be adequate for ipsec, But you may need to also enable that feature an other with the following command:
license boot level network-xxxxx
Kind Regards
Paul
