Catos 6509 and MSFC
eng.bandar
If we have catos 6509 and MSFC and we need to connect new building with L3  I want to
Do static route between two network i need to but ip in interface of switch should I but this ip on catos or MSFC,
Switch(config)# interface fastethernet 2/1
Switch(config-if)#  ip address x.x.x.x x.x.x.x
In catos if want want do like above command what is the command
Thank  you
You can't apply an IP address to an ethernet switchport on 6500 running CatOS on the supervisor. There is no equivalent of "no switchport" that you get with IOS.  So what you need to do is -
1) create a new vlan in the vlan database. This vlan will only be used for the inter-site connection. So lets say you create vlan 10.
2) assign the port fa2/1 into vlan 10
3) then on the MSFC create a L3 vlan interface for vlan 10
int vlan 10
ip address x.x.x.x
only fa2/1 will be in vlan 10, no other ports.
This is the only way to do it with CatOS running on the supervisor.
Jon
6 Replies 6
Reza Sharifi
You cannot do this command in Catos.  Catos is layer-2 only.  You need to configure this command on the router (MSFC) the same way you have it here.
Reza
ok I will use MSFC but this MSCF cannot see the modules of switch
if you need my config i will make copy
eng.bandar
int vlan 10
ip address x.x.x.x
Jon
hi you ideas. is ok but I will connect two L3 network in diffrenet building in same compus so I will need real ip in the interface to make static route.   if I used you idea cannot make static route   I will but some digram of this idea
Posted from my mobile device.
You don't need an IP on the interface to use a static route. And i say again, with CatOS this is the only way to do it, you cannot assign an IP to an ethernet interface.
Your route on the other switch would simply be -
ip route x.x.x.x  <-- where x.x.x.x is the IP address assigned to the vlan 10 interface on the CatOS switch.
Jon
