CATOS-how to change the password
WEERAKOO69BA
Can anybody give me the steps for change passwords
(enable,secret,username) in 4006
CATOS base switch?
thx
Giuseppe Larosa
you need to use set based commands:
set password
set enablepass
see catos config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/configuration/guide/configur.html
start by reading
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/8.3and8.4glx/configuration/guide/cli.html
I don't remember that enable secret is supported
all this under the hyphotesis you know current enable password and the way to login to the box
otherwise you need to use a password recovery procedure
Hope to help
Giuseppe
thx
