CBWFQ : Can be enabled as an output feature only
aoshea
Dear support,
I have configured a QoS policy, but am unable to apply it to an interface. (have had to apply it as output service-policy)
The following statement is produced if I try to apply the service-policy to the inbound interface;
Can anyone help me as I seem to be digging a hole. (all I want to do ensure 50% of the bandwidth is reserved for voice, that is already mark with the dscp value of 'cs5' via the third party phone.
Thanks in advance,
Regards, Adrian
Thanks in advance
5 Replies 5
mheusinger
Level 10
Level 10
Hi Adrian,
your policy looks somewhat like this:
class-map VoIP
match ip dscp cs5
policy-map Out
class-map VoIP
priority percent 50
class class-default
fair-queue
random-detect
interface Serial0/0
service-policy output Out
Well this means you enable Class Based Weighted Fair Queueing (CBWFQ), or better Low-Latency Queueing (LLQ), which is an output ONLY feature on standard routers. So IOS tells you that it can not be applied inbound.
Make sure to use the "priority percent" command and not "bandwidth percent" as the latter does not guarantee lowest delay.
Martin
Hi Martin,
Many thanks for your response.
I have several site routers, all 2621 xm's that have are connected via fa0/1 to LAN and fa0/0 with sub interfaces to the wan (have a 2Mbps connection to the HQ site).
If I try to apply the service-policy to the sub int, I get the following;
CBWFQ : Not supported on subinterfaces
I have the following config (obviously trimmed down).
(it seems to work, as tested with large transfer, but being a qos novice, I am not completely sure i've done the config right).
Thanks again, regards, adrian.
class-map match-all BULK-DATA
match ip dscp af11 af12
class-map match-all INTERACTIVE-VIDEO
match ip dscp af41 af42
class-map match-all VOICE
match ip dscp cs5
class-map match-all MISSION-CRITICAL-DATA
match ip dscp 25
class-map match-all ROUTING
match ip dscp cs6
class-map match-all SCAVENGER
match ip dscp cs1
class-map match-all NET-MGMT
match ip dscp cs2
class-map match-any CALL-SIGNALING
match ip dscp cs3
match ip dscp af31
class-map match-all TRANSACTIONAL-DATA
match ip dscp af21 af22
policy-map BRANCH-WAN-EDGE
class VOICE
priority percent 50
class INTERACTIVE-VIDEO
priority percent 2
class CALL-SIGNALING
bandwidth percent 5
class ROUTING
bandwidth percent 3
class NET-MGMT
bandwidth percent 2
class MISSION-CRITICAL-DATA
bandwidth percent 5
random-detect
class TRANSACTIONAL-DATA
bandwidth percent 2
random-detect dscp-based
class BULK-DATA
bandwidth percent 2
class SCAVENGER
bandwidth percent 1
class class-default
bandwidth percent 3
random-detect
interface FastEthernet0/0
no ip address
no ip split-horizon eigrp 100
duplex full
speed 10
no mop enabled
interface FastEthernet0/0.1106
description *** primary wan connection ***
bandwidth 2000
encapsulation dot1Q 1106
ip address 172.16.31.34 255.255.255.252
no ip redirects
ip bandwidth-percent eigrp 100 90
rate-limit output 2000000 2000000 2000000 conform-action transmit exceed-action
drop
interface FastEthernet0/0.1116
description *** backup wan connection ***
bandwidth 1999
encapsulation dot1Q 1116
ip address 172.16.32.34 255.255.255.252
no ip redirects
drop
interface FastEthernet0/1
description Connection to LAN
service-policy output BRANCH-WAN-EDGE
Oh, that gives a different picture.
Well you do NOT do the right thing now.
Applying the policy BRANCH-WAN-EDGE to F0/1 does not do anything. Queueing - as activated by "priority" or "bandwidth" in the policy - will only be invoked when your interface is overloaded. This will never happen in your setup, i.e. when feeding a FE with only 4 MBit.
So what you need is a so called nested policy. Try this:
policy-map Shaper
class class-default
shape 1984000
bandwidth 2000
no ip redirects
service-policy output Shaper
bandwidth 1999
no ip redirects
REMOVE the rate-limit statements (they are policing your traffic, which is NOT what you want). remove the service-policy from F0/1 there is no effect of it (other than to confuse people).
What that will do: limit all traffic through FastEthernet0/0.1106 to 2 MBit/s and guarantee out of these 2 MBit/s 50% to voip etc if requested.
Martin
Hi Martin,
Many thanks again for your assistance, I think muddled my way through and come up with the following as per your example.
policy-map Shaper
class class-default
shape average 1984000
service-policy BRANCH-WAN-EDGE
i'm not sure if i need the shape average or shape peak command (look the same)
shape ?
adaptive Enable Traffic Shaping adaptation to BECN
average configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
send out Bc only per interval
fecn-adapt Enable Traffic Shaping reflection of FECN as BECN
fr-voice-adapt Enable rate adjustment depending on voice presence
max-buffers Set Maximum Buffer Limit
peak configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
send out Bc+Be per interval
but think it looks ok? (are buffers set ok?)
sh policy-map
Policy Map Shaper
Class class-default
Traffic Shaping
Average Rate Traffic Shaping
CIR 1984000 (bps) Max. Buffers Limit 1000 (Packets)
many thanks for your help.
regards, adrian.
Hi Martin,
Sorry, last question (I have the QoS study guide on order)
on the HQ site (or one of the two), how should the policy be set?
Each HQ site has a LES 10 rather than a 2Mbps connection.
All spoke-to-spoke traffic goes via one of the hub sites.
please see extract below;
interface FastEthernet1/0
no ip address
speed 10
full-duplex
interface FastEthernet1/0.1100
description **
bandwidth 1999
interface FastEthernet1/0.1111
description ***
bandwidth 1999
interface FastEthernet1/0.1113
description **
bandwidth 1999
interface FastEthernet1/0.1114
description ***
bandwidth 1999
interface FastEthernet1/0.1115
description ***
bandwidth 1999
interface FastEthernet1/0.1116
description ***
bandwidth 1999
ip address 172.16.32.33 255.255.255.252
no ip redirects
rate-limit output 2000000 2000000 2000000 conform-action transmit exceed-action drop
do i need a separate policy-map for each sub-int or can it been done with a single one?
thanks again, regards adrian.
