CBWFQ : Error! shape pointer NULL
wrighd.cisco
Hi All
Any one know what this error could mean? when trying to place another service policy inside another policy ( Nested policy ) using MQC.
Cheers
abaskara
Hi there,
Can you give some details on the policy-map you have, the interface you are applying it to, and the IOS version you are running ?
Can you also try removing and re-adding the "shape" command that you currently have in the policy-map, and see if it takes the policy ?
Arun
