CBWFQ Problem on Interface GigEthernet in router 7606
blackhat2020
Hi,I have a strange problem in configuration of shapping on interface gig in router 7606.first let me give my configuration and then explaine the problem.
class-map match-all AF21
match dscp af21
class-map match-any AF31
match dscp af31
match access-group name MANAGEMENT_TRAFFIC
class-map match-all test
match any
policy-map VSAT
class AF21
bandwidth percent 60
class AF31
set dscp af31
class class-default
fair-queue
random-detect dscp-based
policy-map VSAT-OUT
class test
shape average 620000 2480 2480
bandwidth 620
service-policy VSAT
main policy is VSAT-OUT witch it will shape the traffic to 620kbps in output direction of the interface GigEthernet.it has a child policy named VSAT witch main goal of this policy is to reserve 60 percent of the bandwidth for AF21.so notice that this policy map(VSAT-OUT) can be configured easily on interface multilink but when i try to configure it on interface GigEthernet it failes and gives me this error:"Bandwidth command is not supported on this interface configuration failes on interface gig 1/4" notice that even i removed the bandwidth from VSAT-OUT policy and childe policy(VSAT) witch containes bandwidth allocations.even with this configuration configuration again failes in this time with error that says shapping is not supported on this example.in the end of this story i figure it out that i cant configure any shapping or any policy that allocates bandwidth on interface gig.my ios version is s72033-jk9o3sv-mz.122-18.SXF11.what do you suggest to configure policy VSAT-OUT on interface Gig without changing the ios!!!! thanks
Giuseppe Larosa
Hello Sevan,
what type of linecard is module 1 ?
Best Regards
Giuseppe
