CCIE Rack Rental
jpl861
Level 4
Level 4
I'm looking for a CCIE lab that I can rent and I came across this provider.
http://www.ccierackrentals.com/
I'm not sure if this is legit because they have really good price.
However, I accidentally came across this link as well, they have the same logo and price but the website looks bare and I asked the tech support of the first link and they say they are not aware of the 2nd link.
http://ccierackrental.com/
Is this safe or legit?
John
18 Replies 18
Reza Sharifi
Try this link:
They are safe and legit
http://www.ine.com/rack-rental-tokens.htm
Vinit Jain
I actually used the rack from CoderGenie Technologies.. Amazing service and quick response.. n i also feel they are amongst the cheapest..
http://www.codergenie.com/ccie-rack-rentals
Thx
--Vinit
      I am also using this CCIERACKRENTALS.com in preparation for my LAB simulation exams. They are safe, nothing to worry and feel free to ask sales invoice if you need it for the purchases you have ordered. Good thing with this rack rental, they have immediate response support if in case you encounter technical issues. Try to avail their promo and see for yourself. Go! Go! CCIE Good Luck!
jyotikumar39
Hi John,
http://www.ccierackrentals.com/ is very good for practicing your ccie lab exam on real harware no fake. i personally used the same and found very good and fast , i even used in low access link and able to work and access the all rack routers. they provide you the remote desktop due to this its very safe and low bandwidth consuming so that you and all can use the racj for longer durationn with no high internet cost.
also technicical staff are quick and active to provide the service during your session. if they found any issue during your session and you reported the same they will refund your point very quciky with no arguments except there is no access link issue. and this is true and trusted by me. i faced the same issue and creadited back points to my account so that i can use the another session for free with no cost.
also cost of rack rentals is very low 19 $ for 4 hrs session and u can use for 8 or 12 hr back to back also if want for longer duration....really nice and reliable...
feel free to ask any question and best of luck for CCIE .....
use and belive ...
kumar jyoti.
aragudos516
Hi John,
CCIERackRentals.com is a best rack rental for CCIE track that I found so far. The support is fast and they have professional and knowledgeable support group to assist you should you encounter any issues during your session.
They also provide real racks with physical devices so you can practice at your convenience without worrying that the lab is not incomplete or slow. In fact, you can telnet to the racks easily as long as you have connection to the internet, no bandwidth requirements at all.
The best thing is that they provide you a free trial session so you can get a feel of the racks and then you can decide afterwards. Plus, they have low rental prices! Check our their Hall of Fame and you'll know why many chose to use their services.
You can try it yourself, best of luck to your exam!
ccieseeker
Hi john
CCIERackRentals.com is old website with high end support for users , respones time is quick like a thunder , plus , well organized templates configurations , so you can start where your last session has endup , like intial configurations , Layer 2  and layer 3 configurations .
Racks physical connectivity diagrams always clean and clear , mapped correctly to real rented equipments  , here is the best unique feature in ccierackrental than other online rental , their steup guide is wonderfull and very helpful incase you erased or deleted the ios , configuration etc.. , its very helpful and can do the job in less than a minute .
Plus , prices is affordable and you can easily schedule your sessions within minute , beside all of that they have more than 5 racks serving multiple users in the same time with same quality .
my advice to you , if you would like to acheive your goal with less headech , CCIERACKRENTALS.COM is the best way to do it .
Good look with your rack rental
emanuel360
I used ccierackrentals.com last friday and it worked very well to me.
I used putty to open my several sessions to their rack and then I would use a multi tabbed utility with putty to open all my sessions in the same windows. It worked great!
It wasn't my first time in accessing remoto racks but this one was much better for a pretty affortable price.
Best Regards,
Eman uel Santos
NaderZaki
Hi John,
Yes, http://www.ccierackrentals.com/ is completely safe to use. I am using it myself and it is fast, reliable and they really have very good prices especially in this time of the year. You can do whatever tests you want with their powerful and variable platforms. When it comes to CCIE Lab then for sure you need to practice on real routers and switches then I totally recommend http://www.ccierackrentals.com. They are highly graded in each blog as well.
Good Luck
http://www.ccierackrentals.com/  is good and they provide quick & excellent support . I find they have good number of racks and they provide  4hrs session, so its easy to use and schedule.
My Fridends also recomended it as the best to prepare for the lab.
hamil
aqeel ahmed
http://www.ccierackrentals.com/ is best option for rackrentals, i have been using their services since past one year and they are amazing. During this period i never encountred any hardware or access related issues. They are good in support and rate is best available with no forcefully closing the session 30 mins before.
Good Luck
Jibran Aziz
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA | CWNA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
BGP65111
www.ccierackrentals.com is the best They have 24x7 support and real Devices
Realy they are Very Good.
BR,
SULTAN
thangavel12
One of my friend had used the rentals racks from this coimpany for practising and passing the CCIE LAB. They are quite economical compared to other rack vendors in the market and the best part is you get an excellent support which is kind of instantaneous support.
In short, a good value for your money and you will never be disappointed.
