CDMA interface is not getting IP address
selva Kathir
Dear Experts ,
We are setting up an office WAN setup  with CDMA as backup link.
We are using PAP as the authentication protocal.
We are not getting IP address assigned in the CDMA interface.
When we give static IP address it working we can able to reach the other end office also.
Please find the attached Debug logs when we tried to initiate the Call from the router.
Please guide me !!
thanks in advance...
Selva...
Hello.
Please provide configuration for "without ip address" case. It should be configurd with ip add nego / ip add dhcp
Are you sure opposite side is configured to provide you an IP-address?
PS: why don't you use persistent connection and why do you use C0/0/0 interface and not a dialer ?
