CDP neighbor connection on 9300
Leftz
Level 4
Level 4
Hi Three switches are connected to each other. The Core switch is stacked with two switch. Command show cdp neighbor indicates the same interface are shared. Not sure how they are connected. Looks like there is device that connect three device. Anyone can explain it? Please see attached diagram. Thank you
2 Accepted Solutions
Hello
That diagram doesn’t make sense in relation to the port allocations
Kind Regards
Paul
Leftz
Level 4
Level 4
That is why I post the diagram here for expert to explain. Its different with normal one. I am sure that is what i can see via cdp command
BTW I can see your reply is marked as "Accepted Solution". I did not agree with it. I do not know why it happened. Maybe the system has some problem.
Hello
Kind Regards
Paul
Leftz
Level 4
Level 4
