Use route-map with tagging in BGP
Gergely Racz
Hello Everyone,
On a Cisco ASR1001 device I cannot attach a route-map (with match tag) to a BGP neighbor. I know in most IOS releases we cannot use tags with BGP, and communities should be used instead. But it would be much easier to find an IOS release which supports tagging. The question is whether such an ASR IOS exists where I could use tagging.
My current IOS: System image file is "bootflash:/asr1001x-universalk9.16.12.05.SPA.bin
Config is the following:
asr1001(config)#router bgp 10
asr1001(config-router)# neighbor 1.1.1.1 route-map RM_TAG out
% "RM_TAG" used as BGP outbound route-map, tag match not supported
% not supported match will behave as route-map with no match
route-map RM_TAG deny 5
 match tag 300
route-map RM_TAG permit 10
match ip address prefix-list PL_XY
set metric 200
route-map RM_TAG deny 20
Thanks in advance,
Gergely Racz
Harold Ritter
Hi @Gergely Racz ,
This restriction has been there since day 1 and is still there in the latest IOS or IOS-XE versions. There are ways to handle this though. You can generate a community based on the tag, when you originate the route in BGP (either using a redistribute or network statement) and match on that community in the outbound route-map.
follow
Harold Ritter
Hi @Gergely Racz ,
