CEF No_route
milan.kulik
Level 10
Level 10
I can see
Router1#sh cef drop
CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP      11181644          30746                       0                  479299                0        3           992
on my router with the number of   No_route increasing.
   Looking to the Command Reference, No_route " Indicates the number of packets dropped due to a missing  prefix in the FIB table."
  What I don't understand is:
When there is a static default route present in the RIB (my case), how can any packet be dropped due to "missing prefix in the FIB"?
Milan
gephelps
Can the router resolve the next hop for the default route?
Yes, it can.
The only non-standard fact is it's using a recursive route lookup for the default route next-hop:
Router1#sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "static", distance 1, metric 0, candidate default path
  Redistributing via bgp 65000
Routing Descriptor Blocks:
  * 192.168.189.6
Route metric is 0, traffic share count is 1
Router1#sh ip cef 200.1.1.1
0.0.0.0/0, version 20760790, epoch 0, per-destination sharing
0 packets, 0 bytes
Flow: Origin AS 0, Peer AS 0, mask 0
  via 192.168.189.6, 0 dependencies, recursive
    next hop 192.168.167.3, FastEthernet0/0 via 192.168.189.0/24
valid adjacency
  Recursive load sharing using 192.168.189.0/24.
BR,
Milan
