cef pbr and show ip cef
Krasnoperov
Hello, can anyone explain this situation for me?
I have a router ISR 2 3945(IOS 15.0), and I have PBR on some interface, I know that from 12.0 IOS release PBR is cef swiched (not process swiched), when look into cef table with show ip cef, I dont see any records related to my PBR, for example
route-map XXX, permit, sequence 10
  Match clauses:
    ip address (access-lists): XXX
  Set clauses:
    ip next-hop 1.1.1.1
access-lists XXX
Extended IP access list XXX
    10 permit ip any host 212.192.128.32 (11 matches)
but when I do show ip cef, I see only defaul gateway record
sh ip cef 212.192.128.32
0.0.0.0/0
  nexthop 2.2.2.2 GigabitEthernet0/1.202
Is that means it PBR not cef swiched ?
thanks
ajay chauhan
Level 7
Level 7
Its CEF switched only but whatever you are seeing is just the global table of cef. no extra configuration is required for CEF based PBR as soon as you configure PBR its on.
Ajay
hi,
is there any method to view not only global cef table, but also a cef table for PBR
AFAIK, PBR doesnt create a seperate cef table. It's all in the global cef table Seperate cef tables are created when you have seperate instances of the routing table which are called VRF's but is not related to PBR.
If you want to know whether your PBR is working. just check " sh ip access-lists" and check for the hits in the ACL you are using for the PBR policy which you are already seeing. If you want to know wheter your PBR is being cef switched then check the IOS verion you are running via the software feature navigator.
Kishore
